Author Topic: broken down ***UPDATE-New head bought!***  (Read 39788 times)
jamie16v
Re: broken down *now with vid PAGE 4*
« Reply #40 on: 16 February 2011, 21:19 »
You need to get the bottom cover off really to get a better look, can't really tell from the vid as it's not long enough.
 Put the car in fifth gear and get someone to push it while you watch the belt, that would rule out the starter motor.
+1, or jack up one side and turn the wheel by hand..
« Reply #41 on: 16 February 2011, 21:22 »
Vid needs to be longer but sounds like no compression
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #42 on: 16 February 2011, 22:41 »
valves have gone i recon.. not as hard of a job as it sounds.. its just more daunting going over it in your head.. sell some of the mod bits to pay for fix !!
Offline Dave_IOW
« Reply #43 on: 18 February 2011, 17:14 »
Will this work then? Can do this tomorrow just to check?
Just take cam cover off and try to spin jacked up wheel?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Mr_Orange
« Reply #44 on: 18 February 2011, 18:03 »
Guess so.  With it in gear yes?  :undecided:
Weird.  Video sounds like only the starter is spinning and nothing else.  You think it might be turning the crank which aint connected to the cambelt anymore (ie Cam gear aint turning)?  Slipped the keyway off the lower pulley perhaps?
Good luck with this mate, I hope its something silly (ie cheap to fix).
Also good luck with the move!
Build thread clicky
Offline tech1889
  • Mk2 GTI FTW !!
« Reply #45 on: 18 February 2011, 19:19 »
just take cam cover off and put a bit spanner on the nut and turn the engine over..
Offline Dave_IOW
« Reply #46 on: 18 February 2011, 19:50 »
This is certainly what it sounds like to me!
Hoping for an easy fix to, but knowing my luck 101% sure it wont be  :laugh:
Offline cullygti
« Reply #47 on: 18 February 2011, 20:06 »
like mine then dude only luck i get is bad friggin luck  :evil: :laugh:
Offline Dave_IOW
« Reply #48 on: 19 February 2011, 13:33 »
Right guys, is it the bottom cover i need to take off aswell as the top??
Offline Dave_IOW
« Reply #49 on: 19 February 2011, 14:01 »
Right top cover off and looking at belt, its exactly how it should be.
Have remove AUX belt and 3 bolts for bottom cover but cant see how do get it off?
