Author Topic: Dash lights going out with headlights on- faulty switch?  (Read 4894 times)
Offline rob.043
Wee problem to sort on a friends car, its a GL with hazard switch on the dash.
All the dash lights work with the light switch pressed in one notch (side lights on) but go out when its pushed in the second notch (headlights on).
Is it likely this is just a faulty switch?
Offline SoundillusioN
Re: Dash lights going out with headlights on- faulty switch?
« Reply #1 on: 10 February 2011, 09:32 »
My mk1 did similar, turned out the switch was faulty.  Have you tried fiddling with the fader for the dash lights as these are normally the first thing to start going, if they flicker when you move the dial then it's a bit tired,  but can be cleaned up without too much hassle or replaced from various other dubs of a similar year...
Offline rob.043
« Reply #2 on: 10 February 2011, 09:41 »
The fader seems ok, with a good contact from the connector legs.  I had thought it would be the switch as the dash light are bright then just go out on moving the switch from position 1 to 2 (sidelights to main).
Switches dont seem to be too much, so we'll probably just get one...
« Reply #3 on: 10 February 2011, 10:02 »
it could be either the headlight switch or the flasher switch in the stalk, can you flash the main beams with it?
Offline rob.043
« Reply #4 on: 10 February 2011, 11:16 »
Yes, main beam will flash and stay on with the stalk.
its an 11 pin switch, will any 11 pin replacement be the same?
« Reply #5 on: 10 February 2011, 11:47 »
oops ignore me i thought you meant headlights go out.
yep any 11pin switch will be a direct swap :)
Offline rob.043
« Reply #6 on: 10 February 2011, 12:43 »
Aye, its just the dash lights....  Thanks for the info RJ, i'll get to ebay for a replcement.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #7 on: 10 February 2011, 16:35 »
I've got a couple if interested - one came off my car as I have just replaced all my dash switches with new ones!!
For More Info Click To See;
Offline rob.043
« Reply #8 on: 10 February 2011, 16:49 »
Thanks for the offer, just got a second hand one from the bay
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #9 on: 10 February 2011, 17:16 »
Kool
