Author Topic: ABS Talk to me  (Read 2548 times)
Offline GAM2000
ABS Talk to me
« on: 04 February 2011, 20:19 »
Hi all, I have the abs light on so i checked all the sensors and the osr was way different, off i went to gsf and got me a new one, as soon as i got home i plugged it in expecting the light to turn off but it didn't  :cry: , do i need to reset something or is it down the the pump  :sad:
Thanks all
Offline tweed
Re: ABS Talk to me
« Reply #1 on: 04 February 2011, 20:21 »
I believe it will sort it's self out. Maybe go somewhere safe and brake hard to see if that restets it
Offline Mike87Turbo
Re: ABS Talk to me
« Reply #2 on: 04 February 2011, 20:40 »
You may have to reset the ABS light with suitable diagnostic equipment to clear the fault codes it has brought up!
Offline GAM2000
Re: ABS Talk to me
« Reply #3 on: 04 February 2011, 21:02 »
thanks
do i need to take the rear disk off to fit the sensor
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: ABS Talk to me
« Reply #4 on: 04 February 2011, 21:48 »
It depends on whether you break the old one when removing it which tbh is highly likely. It's not a difficult job to fit them, just irritating when they snap.
« Last Edit: 05 February 2011, 00:28 by thai-wronghorse »
Re: ABS Talk to me
« Reply #5 on: 04 February 2011, 23:45 »
It will need the codes clearing.  :smiley:
Re: ABS Talk to me
« Reply #6 on: 05 February 2011, 00:29 »
Vagcom is your friend
Offline GAM2000
Re: ABS Talk to me
« Reply #7 on: 05 February 2011, 07:56 »
OK if i can fine somewhere dry tomorrow I'll give it a go
thanks again  :smiley:
Offline tshirt2k
  • Been there...Done that...
Re: ABS Talk to me
« Reply #8 on: 05 February 2011, 08:49 »
Most likely will snap. But the mk3 can also suffer with controller problems also. So vag com would be a good buy.
Mk3 ABF 16VT Megasquirt V3
Offline GAM2000
Re: ABS Talk to me
« Reply #9 on: 05 February 2011, 10:39 »
I have got vag com but only iv only had it about a month and dont know how to use it, iv not had time to sit down and have a good look
