Author Topic: ABS Talk to me  (Read 2551 times)
Offline Mikester
  • Civic Type R
Re: ABS Talk to me
« Reply #10 on: 05 February 2011, 12:06 »
I take it from later on asking if you need to take the disc of that you have plugged this sensor in not fitted hoping the code will go?
You need to fit the new sensor, then take it for a drive and if that is the only fault it will clear itself. You dont need Vag.com etc for this. Over the years i replaced all of my abs sensors at least once (buy cheap buy twice).
There is a how to thread on here about removing them but i found the easiest way is to smash it into bits with a chissel and pull the bits out.
You might also need to sand down the case of the new sensor to get it to fit as i found the replacement ones were not a good fit.
Offline Mikester
  • Civic Type R
Re: ABS Talk to me
« Reply #11 on: 05 February 2011, 12:07 »
Offline thai-wronghorse
  • mk1 Seat Leon FR TDI
Re: ABS Talk to me
« Reply #12 on: 05 February 2011, 13:01 »
Every single one ive done over the years i had to sand down the casing to some degree, some took more effort than others admittedly.
Offline Mikester
  • Civic Type R
Re: ABS Talk to me
« Reply #13 on: 05 February 2011, 13:23 »
Yeah i agree, i normally bolt it in half way, it gets stuck, remove it, sand it, refit, gets stuck, remove, sand more, swear a lot and after about 6 attempts get it in place.
Also watch you knuckles on the brake disc when u bashing it out!
Re: ABS Talk to me
« Reply #14 on: 05 February 2011, 13:29 »
One of many joys of maintaining your own cars.  :smiley:
and no, it's not the ownership of a kack watch.
« Last Edit: 05 February 2011, 13:31 by thai-wronghorse »
Offline GAM2000
Re: ABS Talk to me
« Reply #15 on: 05 February 2011, 15:20 »
Again thanks to every one,
f it im going out in the rain
Offline GAM2000
Re: ABS Talk to me
« Reply #16 on: 05 February 2011, 19:15 »
Ok all done, it was pissing it down and a bit Windy but i was going to get this done, i tried to tease it out with a blunt chisel but it broke off flush :rolleyes: so off come the disk only took 10 Min's so not too bad. BUT light is still on iv only took it for a little drive so tomorrow I'll give it a good run soon as i find out why its started running bad.
Offline GAM2000
Re: ABS Talk to me
« Reply #17 on: 05 February 2011, 19:23 »
ps it was the OSR sensor
Offline GAM2000
Re: ABS Talk to me
« Reply #18 on: 06 February 2011, 17:15 »
The light has not gone out.
tried the vag thing and this what it told me
VAG-COM Version: Release 409.1-US
Chassis Type: 1H - VW G/J/V Mk3
Scan: 01,02,03,08,15,25,56
Address 01: Engine
   Controller:
   Note: Excessive Comm Errors
Address 03: ABS Brakes
   Controller: 3A0 907 379 A
   Component: ABS/EDS ITTAE 20 GI V00
   Coding: 03604
   Shop #: WSC 00000
No Faults Found
  or DTCs not supported by controller
  or a communication error ocurred
Offline Mikester
  • Civic Type R
Re: ABS Talk to me
« Reply #19 on: 06 February 2011, 17:18 »
If the light has gone off then its all good.
