Author Topic: Front wheel arch corrosion  (Read 32831 times)
Offline petetan
Re: Front wheel arch corrosion
« Reply #60 on: 21 September 2011, 06:53 »
Just heard back yesterday about mine and VW have authorised the repair
http://www.golfgtiforum.co.uk/index.php?topic=202131.0
Offline Phil1980
« Reply #61 on: 21 September 2011, 12:12 »
Just had an e-mail from vw about the corrosion on my sill, they will pay 100% of the cost.  Quite impressed with this, they got back to me in eight days and I am now just waiting for a time to get it into the bodyshop.  Good work VW, I was expecting more hassle than this. :smiley:
MK5 2005 GTI, BLACK, 3 DR, 18" MONZA II, XENONS
Offline petetan
« Reply #62 on: 21 September 2011, 13:16 »
Pleased to hear, I had no trouble getting 100% either must be new policy to just do the work without the hassle, It took 6 weeks for them to get back to me though
Offline Silver-Leon
« Reply #63 on: 21 September 2011, 16:58 »
Good to read that you're getting it repaired,I'm still waiting, should hear by end of the week, so fingers crossed.
Offline robby
« Reply #64 on: 25 September 2011, 20:17 »
Just bought a 2007 Golf and now seen these posts - very worrying  :sad:
Prevention is better than the cure so if i remove the liners and paint underseal on the inner lip edge (refitting liners when dry)  will this stop it happening?
Offline Phil1980
« Reply #65 on: 25 September 2011, 23:33 »
It can only help doing a bit of work to try and prevent it but it will probably happen sooner or later.  Seems to be the early cars now becoming affected.  Mines a 2005 plate and is having the work done in a couple of weeks.  Just keep a close eye your arches and get it straight into the dealer as soon as you see any signs of corrosion.
Offline robby
« Reply #66 on: 01 October 2011, 18:27 »
well decided to give mine a check over today while cleaning the calipers
I saw on a forum (can't remember which 1) about the mk4s having rust problems on the front wings and someone posted a pic of a sound deadening pad behind the wing which was acting as a sponge so it was always damp, the conclusion was to cut a couple of inches off the end where it rests on the inside of the wing.
I was suprised to find my 07 has these on the inside as well so decided to cut the ends off as the poster said it was recommended to do this (on the mk4)
I also painted some hammerite type of paint (supposed to prevent rust) on the insides of the wing lips for precaution
Lets hope this stops any future rust problems  :smiley:
Offline mossy69
  • 2014 Gtd carbon grey pro nav dyn audio keyless wp
« Reply #67 on: 01 October 2011, 19:35 »
hi there i had a slight bit of corrosion on my rear wheel arch,took it to silvelink wallsend ,i knew they would come up with some excuse ,they said that the panel had been painted due to a difference in the paint thickness,i knew the back door had been painted because newcastle audi done it ,,,vw benfield sh!te never go back ,take my car to vw indy dealer in blyth fab service everything.VW customer care terrrible icould tell you more but what the heck
2021 Gti moonstone grey 19 Adelaide HUD winter pack
2014 GTD carbon grey pro nav dyn audio keyless
Offline Phil1980
« Reply #68 on: 04 October 2011, 09:17 »
Just dropped my car in ar VW for the work to be done on my sill corrosion, hope they get it right first time.  No GTI until Friday, but I do have the luxury of a 1.0 litre VW Fox until then, :grin:
Offline Phil1980
« Reply #69 on: 08 October 2011, 10:40 »
Well just picked my car up and the quality of work is top notch, the guys at the bodyshop also repaired along the sill where the paint was bubbling this wasn't even going to be covered as it was classed as wear and tear.  Well chuffed with the quick turnaround.  Hopefully won't need to be seeing VW again anytime soon.
