Author Topic: memory wire  (Read 6414 times)
Offline mick ov mids
memory wire
« on: 30 December 2010, 19:55 »
brought a new sony head unit today and need to wire in the memory wire, what colour wud this be on the h.u harness and also on the vw harness? cheers
mick ov mids
[img width=500 height=200]http://i836.photobucket.com/albums
Re: memory wire
« Reply #1 on: 30 December 2010, 20:57 »
bump
Offline troublestarter
Re: memory wire
« Reply #2 on: 30 December 2010, 21:14 »
which model golf would help
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Re: memory wire
« Reply #3 on: 31 December 2010, 02:24 »
99 mark 4, sorry lol
Re: memory wire
« Reply #4 on: 31 December 2010, 11:29 »
it should have a permanent live in the loom already
there is more than one fuse for the stereo on a mk4 golf so check your fuses
Offline hainesz
  • MK4 GTi 1.8T 20v AGU
Re: memory wire
« Reply #5 on: 31 December 2010, 11:32 »
the red wire on the stereo harness is permenant live and yellow is ignition live, if the stereo isnt remembering stations ect ect you need to swap the red over with the yellow... there should be bullet connection on these 2 wire to do this
...Burn Rubber...Not Your Clutch...
Re: memory wire
« Reply #6 on: 01 January 2011, 00:37 »
cheers chaps
Offline hainesz
Re: memory wire
« Reply #7 on: 01 January 2011, 17:42 »
cheers chaps
you sorted it now? what was it?
Re: memory wire
« Reply #8 on: 01 January 2011, 18:18 »
havnt looked yet mate due to bad weather and major hang over  :grin: ill take a look tomoz and post a follow up plus been and brought a vibe active sub so need to get that changed over with my other sub  :wink:
mick
Offline Ruji
  • Mk3 Golf GTi 8v (96) Anniversary Edition
Re: memory wire
« Reply #9 on: 17 January 2011, 17:47 »
Almost correct...however..Yellow is considered the Permanent LIVE on the sony loom...and the RED is the switched LIVE (ignition).
All VWs with factory plugs on mk4's and below all have the wiring switched the otherway round to cater for the oem radio. so quite rightly so...you will HAVE to switch the red and yellow around on the sony harness in order match up correctly with the vw wiring.
Also, it mite b worth cutting the BLUE connected wire that also runs in line on the sony loom to the car..as that can cause complications.
Hope that helps.
regards
Why pay big bucks when you can do it yourself???
http://i224.photobucket.com/albums/dd23/rujiboy/WheelRefurbishmentProcess1.jpg
sig pic too large, see forum guidelines - admin
