Author Topic: k-jet on bike carbs?  (Read 9037 times)
Offline danny_p
Re: k-jet on bike carbs?
« Reply #20 on: 26 December 2010, 09:52 »
there is no actual experiment to be done..
have met a LOT of 16v 's that are running bike carbs  a couple of them have had real poke. the rest of them were all suffering various degress of lameness and din't run that well.
DH's 2.0  8v  handed a bike carbed 16v it's it arse after thoroghly spanking it.  looking at the engine bay it all looked lik there was potential 200 there till you heard it running up close and smelt it.  AFR's were all wrong as obviously hadn't botherd to set the carbs up with the rght jets or anything once it ran that was enough i think.
end result  naff all power
all the VW's have gone bar 1.
Offline Diamond Hell
  • Opinions я Us
« Reply #21 on: 26 December 2010, 11:35 »
Hahahah - forgot about that at one of the VAG Action Days.  :grin:
Offline Sam
  • Sam I am
« Reply #22 on: 26 December 2010, 12:56 »
When it comes to setting up, there is a bloke in Barnetby called dennis vessey he is a carb god! Also he is pretty damn good with the k-jet
Offline lemski
  • 16v
« Reply #23 on: 26 December 2010, 14:08 »
Cheers caister banetby int that far from me. And it'll be set up. I'll get it running sweet and then take it to rasp to get fine tuned on the rr.
Offline Sam
  • Sam I am
« Reply #24 on: 26 December 2010, 19:15 »
Sorry dude, should have explained better. He isn't just some random bloke. Back in the day he was the man for Webber carbs, he has a few old boys working for him and will get anything running spot on. He has a full RR to set up on and wont let it off it until he is fully happy with it.
Offline lemski
  • 16v
« Reply #25 on: 26 December 2010, 21:50 »
Fairplay. I'll pm u closer to the time to get the details or I'll only loose em.
  • Opinions я Us
« Reply #26 on: 26 December 2010, 23:27 »
Between 2-4k revs with a flat spot around 5000RPM and then for 500 revs from 6000RPM, when it's 18-20degrees C and the car's running on 97RON petrol.  :grin:
And that is why people use throttlebodies.
Offline lemski
  • 16v
« Reply #27 on: 26 December 2010, 23:37 »
And yet am still going to get it all set up deside if I like it or not and then run it as if everyoe strayed away from b/c and did everything the same the world would be a boring place to be honest
  • Opinions я Us
« Reply #28 on: 27 December 2010, 20:23 »
Yes, I'm sure throttlebodies would be very dull....  :grin:
Offline spankier
« Reply #29 on: 27 December 2010, 20:42 »
if you really must go down the carb route, which it looks like you are, then at the very least pay some attention to the ignition system, the one you have now is very limited in its adjustability- this may sound like a minor thing but it really really isnt, firstly any ignition system has less time to soak (charge) the coil as rpm rises and therefore spark energy drops, hence the twin coil systems found on a huge number of modern family wagons, plus if you actually succeed in getting a meaningfull increase in airflow at high rpm/full throttle (the hard bit) and get the right amount of fuel in (the easy bit if you arent bothered about part throttle accuracy too) and get it properly atomised (harder than it sounds) you will need LESS spark advance for a given engine speed- this is because the denser air/fuel charge will alow the flame front to propogate more quickly, the only way to achieve this with a dizzy twisting setup is to retard the spark under all circumstances which will cost economy and driveability, similarly when you get to your desired cruising speed and let off to say 20-30% throttle the amount of air introduced to the engine is reduced enormously and so the spark advnce should be increased to suit, hard to explain but trust me.
as for the 14.7:1 ratio? yes, that is the stoichiometric ratio and the one aimed for by a narrowband lambda, however just whacking a lambda in will get you no closer to achieving your desired ratio without an ecu capable of reading the information it provides and making adjustments based on them. Also stoich/lambda 1 ratio is fine for things like mid-high rpm cruise and light load, or ticking over when warm but under hard acceleration a richer mixture is what you want so a k-jet system that works properly won't just maintain a constant lambda ratio, and isnt supposed to either, its far more complicted than that. it may sound like i hate k-jet but i dont at all, its what gave us the all important little 'i' on the back of our cars and in its day was fitted to some very exotic, expensive, and high performance cars, its just that the day in question was 20 years ago..... also it was a BIG step forwards from carbs and the first one towards the great systems on offer today. Even bikes are almost all running port throttles now, progress you see ;)
the megajolt system http://www.autosportlabs.net/MegaJolt_Lite_Jr._-_A_DIY_Programmable_EDIS_Ignition_Controller_-_Users_Welcome! is probably the cheapest setup and uses ford edis parts (escort/mondeo/ka/fiesta etc) so it is very easy to source parts too, properly installed and set up it is capable of giving a healthy and accurately timed spark under any of the conditions your engine will encounter. the shape of a fully trimmed advance curve when drawn on a graph is nigh on impossible to achieve by mechanical/vacuum means and the cost of the dyno time to get close would far outweigh the cost of something more capable in the first place.
A.G Bell has written various books on engine tuning such as this one (the one i have and has served me very well) http://www.amazon.co.uk/Four-stroke-Performance-Tuning-Graham-Bell/dp/1859604358 if you get a copy read it from cover to cover once, then possibly again, then research every detail of what you want to do by going through the relevant parts and actually working it out. the earlier editions were written at a time when the golf 8v/16v were considered current but before a properly mappable ignition or injection system was readily available to home tuners on a budget so one of the later editions would perhaps be a good idea as well as. oh, and shop around, the link i showed was just first one that came up when i searched- you should get one for peanuts on ebay.
you said you had your carbs already but the bodies i mentioned are up for 150, the injectors are peco type but i may-hopefully- have the connectors for them to go on a suitable loom too. they taper from 50mm diameter at the in end down to 43mm at the out end and are in very very good clean condition. the only thing that needs doing to them is the holes for the secondary ecu operated throttle shaft need plugging or welding- not a hard job if you know what you're doing. plus the obvious like as suitable manifold/trumpets etc to suit
« Last Edit: 27 December 2010, 20:46 by spankier »
