Author Topic: k-jet on bike carbs?  (Read 9038 times)
Offline lemski
  • 16v
Re: k-jet on bike carbs?
« Reply #10 on: 24 December 2010, 21:33 »
right av just researched into the carbs again. so far i have made a list of:
bike carbs
manifold
facet fuel pump
fuel regulator
is there anything i have missed off?
cheers liam
« Reply #11 on: 24 December 2010, 22:00 »
bike carbs
manifold
facet fuel pump
fuel regulator
cheers liam
My 2 pence worth, Carbs are a backward step.
But yes that is all that you will need.
Offline lemski
  • 16v
« Reply #12 on: 24 December 2010, 22:07 »
Yeh but its an experiment. Always go back to k-jet if its not good enough.
Liam
« Reply #13 on: 24 December 2010, 22:12 »
Liam
The trouble is and I guessing your's is a 8v in which case unless you run a crossflow head they are sitting right above a hot exhaust.
Offline lemski
  • 16v
« Reply #14 on: 24 December 2010, 22:15 »
No its a 16valve. I know about the probs with the xvalve having exhaust under the inlet heating the inlet up. Rubbish design really.
Liam
Offline bodga
  • F reg GTI 16v
« Reply #15 on: 24 December 2010, 23:28 »
Here is a vid of my mates setup. I cant remember what bike the carbs are off but the fuel pump was off a bike too delivering about 5psi to the carbs. it still needs setting up properly. the car was a 1.3 and he brought a valver complete for engine and other bits.
he is having an exhaust made after crimbo :grin:
http://www.youtube.com/watch?v=4eMvINzCMe0
« Reply #16 on: 24 December 2010, 23:36 »
Liam
Good luck with it.  :smiley:
Offline lemski
  • 16v
« Reply #17 on: 25 December 2010, 19:25 »
good videoto see how they are put on to the valver cheers for the info
liam
Offline Diamond Hell
  • Opinions я Us
« Reply #18 on: 25 December 2010, 22:29 »
If you're going to experiment with something then experiment with something you can measure and manage - bike throttlebodies instead of carbs - you've got to get the stub manifold made up anyway, so do it properly.
Offline lemski
  • 16v
« Reply #19 on: 26 December 2010, 08:32 »
it is getting done properly, i have thought of some propblems that could occure like the sensors near the airbox on the k-jet, can i leave them unplugged or what. i've seen a full thread on club gti but that wasnt really much help.
liam
