Author Topic: sorting out all the little bugs!  (Read 1362 times)
Offline totallyflockedup
« on: 04 December 2010, 19:59 »
As im a total newbie to golfs i want to try and tidy my first one up abit. iv already done a few bits but the little things need doing which i need some clarification on.
Firstly, and i know it might sound stupid, i need to replace the reverse bulb/bulbs. has the golf got two reverse bulbs or one?
And likewise has the golf got two or one rear fog light?
Secondly on opening the drivers door neither the interior lights or door marker light turn on. cant quite see where the switch is that activates them on any of the seal.
Could someone point me in the right direction please. and last but not least which bulbs do the lights in above the b pillar take.
thanks
« Last Edit: 04 December 2010, 20:33 by richw911 »
Offline richw911
Re: sorting out all the little bugs!
« Reply #1 on: 04 December 2010, 20:32 »
Welcome  :cool:
1 http://www.golfgtiforum.co.uk/index.php?topic=87373.0  Two reverse bulbs  :wink:
2 The mk4 has only ONE fog light that works - although all the part are there for two  :smiley:
3 http://www.golfgtiforum.co.uk/index.php?topic=86403.0
4 see fault 3  :laugh:
« Last Edit: 04 December 2010, 20:34 by richw911 »
« Reply #2 on: 04 December 2010, 20:35 »
cheers, does it have one or two reverse lights though, just incase it is bulb and not switch
Offline richw911
« Reply #3 on: 04 December 2010, 20:38 »
Two  :wink:
Offline richw911
« Reply #4 on: 04 December 2010, 20:39 »
« Reply #5 on: 04 December 2010, 20:43 »
i had a feeling it would be two, means i got to check out the switch then, had the same problem with the hyundai coupe i had.
dont think i can be bothered with doing a twin rear fog set up, though might if i get all the other bugs sorted.
as for the pin for activating the interior lights and door marker im still non the wiser.
Offline richw911
« Reply #6 on: 04 December 2010, 20:45 »
There is no pin. The interior lights are controlled by a "Door module"  which is INSIDE the door.
They are a common failure the solder joints go - read the link  :smiley:
« Reply #7 on: 04 December 2010, 20:48 »
god that seems like effort but needs must i guess!
Offline richw911
« Reply #8 on: 04 December 2010, 20:52 »
Do what i did but a new unit  :wink:
