Author Topic: Twin foglight how to  (Read 12985 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« on: 12 April 2009, 19:48 »
Right then ladies and gents, here's how to get the passenger side fog light working. If you're like me you'll find it annoying that the circuit is there but VW were too tight to run 1 wire across to make it work.
Anyways here we go
Order yourself one of 000 979 133 (repair wire)
If you have a mate who wants this done as well you can go halves on it as you get 2 ends on the wire.
First off solder a bit more wire onto the end of the connection to give you enough to get over to the other cluster
now clip the wire end into the plug on the back of the passenger side bulb holder
then get a piece of stiff wire, run it up from the boot floor then tape the repair wire to it and pull back down to route the wire behind the side panel
then run the wire behind the hard plastic cover at the back of the boot space so the end is at the drivers side boot panel
now run the stiff wire behind the panel. Be warned the terminals for the cigarette lighter are permanently live and touching them will blow the fuse (like I did) If you want to prevent this remove the 30amp fuse from the fuse box (I think it's 3rd one up in the middle row)
now pull the stiff wire through until the repair wire end has come through
then grab a scotch lock or your connection of choice and connect to the grey wire at the end of the plug
turn your fog lights on and check they both work
stand back and admire  :cool:
« Last Edit: 12 April 2009, 20:01 by richw911 »
Offline G60GTI16V
  • GTI Mk1, 2, 3, 4 now VRS Hell Yea!
Re: Twin foglight how to
« Reply #1 on: 27 July 2009, 20:15 »
how much was th repair wire?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #2 on: 16 August 2009, 17:58 »
about a quid mate and it's got a connection either end, so in theory it will do 2 cars
Offline bobbarley
  • I'm kind of a big deal...
« Reply #3 on: 16 August 2009, 18:05 »
Good work mate!
Offline johnomk4
« Reply #4 on: 17 November 2011, 14:33 »
Well happy with this  :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #5 on: 18 November 2011, 14:37 »
No worries, glad I can be of service
Forgot to add you will need another bulb and US/Euro clusters will need the blank snapping out of the hole so the bulb fits
Offline wdw1992
« Reply #6 on: 22 November 2011, 22:17 »
Hey :)
I cant find the 'Repair Wire 000 979 133' anywhere on the net, or maybe im being a numpty  :grin: ... where sells it? online or instore i dont mind.
Thanks!
« Last Edit: 22 November 2011, 22:31 by wdw1992 »
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #7 on: 23 November 2011, 20:58 »
VW dealers mate  :smiley:
