Author Topic: Reversing lights wiring fault.  (Read 11088 times)
Offline richw911
« on: 30 July 2008, 00:46 »
Common fault on the mk4 is the reversing lights to stop working this is usually caused by a the wiring braking off on the switch on the gearbox. Have a look under the cover on top of the gearbox.
Definitely check this first before buying a new switch!!
Have a look at this pic:
The wires are bought seperately from the plug, it depends on the diameter of the wire which repair wire you will need (0.35mm or 1mm) - 1 wire has two connectors on it and can be cut in half to make two repair wires :afro:
« Last Edit: 31 January 2010, 14:41 by richw911 »
Offline big_el
Re: Reversing lights wiring fault.
« Reply #1 on: 20 September 2008, 22:32 »
mine doesnt work
when you say the wire. it isnt this is it ?
Offline richw911
« Reply #2 on: 21 September 2008, 22:52 »
mine doesnt work
Hard to tell from the pic looks like it could well be tho  :smiley:
Offline SLSigiriya
« Reply #3 on: 30 September 2010, 13:02 »
Whether this wire issue would tigger an engine cut off when put to reverse gear. OR this is just for reverse light ??
see my original problem.
http://www.golfgtiforum.co.uk/index.php?topic=168036.0
Offline VW-GOLF-GT
« Reply #4 on: 17 April 2012, 10:05 »
I have a problem, when I put the car in reverse the engine cuts off completely and the cluster goes crazy for few seconds. I removed the reverse bulbs from the holder in order not to let the engine cut off when reversing. But as you know, reverse lights are essential so I must fix this problem. Should I change the switch, or is there a problem with the wiring ? Thanks.
