Author Topic: starting issues after storage  (Read 6945 times)
Offline Guy
« on: 10 November 2010, 12:39 »
right...
mk1 rivage J plate
been off the road 11 months
battery went flat for a short while and has been on conditioner ever since (so battery could be an issue)
reconnected battery... seems to have plenty of juice
get alarm (clifford concept) out of valet mode and into 'normal' mode
oil and water - check
fuel - very minimal (but we're not even getting that far)
ignition comes on when key inserted
go to start engine
there is a feint 'click' and then everything, including all electrics, alarm etc goes dead
this is including when connected to another battery for jump start
thoughts?
Offline Horney
Re: starting issues after storage
« Reply #1 on: 10 November 2010, 12:47 »
Got anyidea where the click is coming from?
Tried hitting the starter with a hammer to see if it's stuck?
Have yo managed to get it to Chuff's or are you needing to fire it up to get on the truck?
nick
Offline Horney
« Reply #2 on: 10 November 2010, 12:48 »
You tried putting th eother battery in? It does sound like the battery is properly dead.
nick
Offline Guy
« Reply #3 on: 10 November 2010, 13:05 »
nick
wont need to start it to get it onto the truck.. hopefully... we we're just going to try and start it anyway  :lipsrsealed:
wouldn't know what to hit... but i think it could very well be the flattery
recovery driver has broken down (doesn't bode well)
Offline Horney
« Reply #4 on: 10 November 2010, 13:07 »
Oh no, it's going to be one of those days isn't it?
Good luck dudes.
Nick
Offline AudiA8Quattro
« Reply #5 on: 10 November 2010, 13:08 »
The click will be the starter motor solenoid.
Are the points on the motor clean and recieving 12v?
Could also be a seized starter motor like Nick said.
Offline Guy
« Reply #6 on: 10 November 2010, 13:14 »
Good luck dudes.
Nick
very much so... seeing as i lost the front bumper of the caddy to a bollard  :sad:
Offline Guy
« Reply #7 on: 10 November 2010, 13:15 »
thank you.. will check it out later  :smiley:
« Reply #8 on: 10 November 2010, 13:19 »
No probs.
Did you check the engine turns over freely by hand before starting it?
Offline Horney
« Reply #9 on: 10 November 2010, 13:19 »
Good luck dudes.
Nick
Noooooooooooooooooooooooo!!!!!!!!!!!!!!!!!!!!!!!!!!!
