Author Topic: Brighter headlights???  (Read 10042 times)
Offline clipperjay
Re: Brighter headlights???
« Reply #30 on: 01 November 2010, 17:44 »
Cool mate MK2 section is pretty chilled and like I say to LOTS OF people don't rise to it, makes no sense on forums, it just puts you in a bad mood! "TWO ROGERS DON'T MAKE A RIGHT"  :laugh:
 :wink:
Offline The Mighty Elvi
  • I'm better than you today.
« Reply #31 on: 01 November 2010, 17:56 »
Jus to clear this up I was quickly called a cu*t for suggesting em. I get dazzled by every new car in the mk2, can't see nout on back roads when on dipped with traffic passing, need to get the mains on asap! If u can't beat em join em I say.unless every1 does away with their hid's its silly to be different and suffer and moan, hids are clearly better- that's y they're commonly used I guess..like I say I know of a few mk2s that have aftermarket hids, they never get flashed 4 dazzling people, never fail mots, never get stopped by the fuzz, and don't really have any probs at all! Win win if u ask me!! Its an opinion based question- no right or wrong answer. Let's have it rite u cud put a quad headlamp grille on and have pukka lites!! No offence intended I appreciate varied answers wen I ask a q..
Clearly in the "opinion" of the Law, you're wrong.
Get over it.
Offline jeremybarker
« Reply #32 on: 01 November 2010, 18:13 »
Seeing as you lot can't decide i've found a solution to suit all,
The helmets optional but if if floats your boat knock yourself out  :grin:
Making up for lost time
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #33 on: 01 November 2010, 18:43 »
PMSL....
Just cos your M8's dont get flashed or pulled don't mean it's right...
As I said there is a MK2 near where my lad lives and he has HIDs and they do blind you...
It's also about having respect for other road users..
Do the Loom Upgrade and you'll notice a big differance you can also take the lamps off and cleann them.
Or even buy new HELLA ones for £20.00 each from BBT's
For More Info Click To See;
Offline cняis
« Reply #34 on: 01 November 2010, 18:45 »
honestly making an uprated loom (which plugs into the existing loom and saves your chopping the original up) isnt very difficult. Shouldnt cost you any more than £25 to make a dipped/main loom:
2x relays,
2x fuse holders,
wire,
spade connectors,
ring connectors,
2x H4 lamp plugs,
solder,
heat shrink,
electrical tape
With a bit of patience and common sense you'd finish it within 4-6 hours at a gentle pace. i did mine over 3 evenings watching TV, and i didnt have a clue  :lipsrsealed: but it helps to draw a diagram based on the matey-matey guide: http://www.matey-matey.com/uprated_headlight_wiring.shtml
your headlamps will get 12v and not 9v; it will make the world of difference, mine were shocking... like driving with candles!
plus you get a sense of achievement from doing it.
failing that buy a pre-made one off ebay for £40-£50. but you'd be a failure.
Offline mk2bal
« Reply #35 on: 01 November 2010, 21:01 »
Peace to all!  Let's not fight amongst ourselves let's slaughter the others. Like I jus slaughtered an astra gsi on way home.. Have it
Offline Diamond Hell
  • Opinions я Us
« Reply #36 on: 01 November 2010, 22:08 »
You really do come across like an ignorant moron.
The relay loom and good quality bulbs is the correct and legal solution, this is not an opinion, it's correct.  You seem to struggle to differentiate between empirical fact and subjective opinion.
Quite who you see as 'us' in this situation I'm not sure.  :rolleyes:
(Had to be edited, shoddy, I know)
« Last Edit: 01 November 2010, 22:44 by Diamond Hell »
« Reply #37 on: 01 November 2010, 22:15 »
You really are an ignorant moron.
The relay loom and good quality bulbs is the correct and legal solution, this is not an opinion, it's correct.  You seem to struggle to differentiate between empirical facy and opinion and subjective opinion.
Corrected for you.  Doesn't happen very often, but there you go.  :grin:
Jonathan.
« Reply #39 on: 01 November 2010, 22:18 »
How a conversation about headlights turns into this i don't know.  :grin:
I do agree that if the lights weren't designed to take HID's then don't fit them if there not going to function properly.
The chap i bought my car off fitted a set of uprated bulbs that have a blue tinge to them and seem to have a two stage process when you switch them on, first the blue then the yellowish light kicks in. Seems to work fine in my car and i live in the middle of nowhere with no street lights.
