Author Topic: speedo going faster than me  (Read 4050 times)
Offline dj g
  • vw gals
« on: 01 February 2005, 14:03 »
 :cry:help my speedo is going faster than me what could it be
Offline gibby
Re: speedo going faster than me
« Reply #1 on: 01 February 2005, 14:43 »
Have you got different size wheels and/or tyres to the originals ?  :undecided: How do you know the speedo is out just out of interest ? Has it been a problem for a while or has it just started happening ?
......now officially dubless.
Offline benmk1
« Reply #2 on: 01 February 2005, 17:44 »
Yea mine does the same, about 10 to 20 mph faster, I think mine is 'cos i got the gearbox from a gti convertable, might just be a later type spedo cable? i dunno but it doesn't both me so i never got it fixed
I don't look at porn much,
usually 2 or 3 minutes is enough
Offline dj g
  • vw gals
« Reply #3 on: 01 February 2005, 18:29 »
Have you got different size wheels and/or tyres to the originals ?? :undecided: How do you know the speedo is out just out of interest ? Has it been a problem for a while or has it just started happening ?
:embarassed:i brought it then noticed
Offline dj g
  • vw gals
« Reply #4 on: 01 February 2005, 18:33 »
:huh:mine is a convertable so don't now just got car :embarassed:so how would i find out about the right cable
Offline Lewizkid
« Reply #5 on: 01 February 2005, 22:38 »
Mine does it too, i've been told that if you've got bigger wheels than the original specs then its just the way it goes. Not much u can do about it ive also been told. You'll just ust have to calibrate it with someone in front of you. Get them to drive at 30 and remember what yours is, then do 40, 60, etc. N.B. I don't condone driving whilst using a mobile phone but unless you;ve got a mate with an excessively loud voice i reckon thats the best way. :grin:
If there is a way round this i'd like to know though?!?
LK
Offline tinman
« Reply #6 on: 01 February 2005, 23:40 »
speedos are always under. rarely over.
bigger wheels generally make the speedo a bit more accurate due the increased circumferance.
the best way of figuring out how bad it is is to use a gps. using someone elses car will only give you an indication of the difference between the two cars.
Offline Dizzie
  • Make friends with your fast
« Reply #7 on: 02 February 2005, 08:00 »
yeah GPS is the best way. mine was within 1mph of the GPS speed all the way up to 120mph and I'm running wheels 3inches bigger than standard!
if you've changed the box you could have the wrong bit in the there reading the speed. I know there's a white and red one in the 140 and 160mph 'boxes for the mk2. maybe that has something to do with it.
is it a constant 10mph out throughout the range or varies? has someone changed your dials to white ones and stuck the needle on in the wrong place. I know mine rests at 10mph and then doesn't move until I get to 11mph.
Mk4 Golf 150PD
Offline hairyarse
« Reply #8 on: 02 February 2005, 16:35 »
Hope this may help chaps?
http://www.nwlink.com/~vdb/vw/Transmission/speed-ratio.html
You can work out the speed you should be travelling at working off your rpm for example so can check how far out your speedo is.
I know on the MK1 you can buy different coloured gears from VW for the end of the speedo cable and these will alter/re-calibrate the speedo to compensate so you dont have to live with it.
There was a posting on old Campaign Register forum with the different types but I think it is a case of trial and error anyway. If you tell the VW parts man what colour gear you have now and if you are over or under reading may be able to suggest which one you need (i.e. with more or less teeth on it)
 :wink:
Offline hairyarse
« Reply #9 on: 02 February 2005, 16:43 »
Here you go, just seen these on Eurocar parts web site... :wink:
DANSK n/a 650440210 SPEEDO GEAR (WHITE) GO1/2/JE1/2/SC/CA (16 TEETH)
Speedo drive (White)  ?2.93
DANSK n/a 650440220 SPEEDO GEAR (RED) GO1/2/JE1/2/SC/CA (15 TEETH)
Speedo drive (Red)  ?2.93
