Author Topic: speedo going faster than me  (Read 3924 times)
Offline dj g
  • vw gals
Re: speedo going faster than me
« Reply #10 on: 03 February 2005, 18:48 »
yeah GPS is the best way. mine was within 1mph of the GPS speed all the way up to 120mph and I'm running wheels 3inches bigger than standard!
if you've changed the box you could have the wrong bit in the there reading the speed. I know there's a white and red one in the 140 and 160mph 'boxes for the mk2. maybe that has something to do with it.
is it a constant 10mph out throughout the range or varies? has someone changed your dials to white ones and stuck the needle on in the wrong place. I know mine rests at 10mph and then doesn't move until I get to 11mph.
thank you dizzie not trying to seem thick but what do you mean by gps
Offline carrie
  • i can see into your soul and its not good
« Reply #11 on: 04 February 2005, 13:39 »
global positioning system, it uses statalites to position where you are an speed is worked out as a function of distance traveled over time
SAY YOU LOVE SATIN?, NO SATAN, ITS SATAN
Offline greenie
« Reply #12 on: 22 February 2005, 18:40 »
God mine has that problem to the speedo is about 15 - 20mph faster than what Im doing  however the
Mileometer works spot on !! Could it be the clock that is at fault !
if anyone knows would love to know how to change it!!! I did change the speedo cable and its doing the same thing!
Greenie xxx
Offline hairyarse
« Reply #13 on: 23 February 2005, 13:13 »
Greenie, take a look at my two posts at the bottom of page 1 - may help you? :wink:
