Author Topic: Immobiliser problem!!! Car start but stalls straight away ??? help!!  (Read 2248 times)
Offline dewmk3
hi, my golf mk3 gti has been standing for a couple of months and i cant get it running? The car start up for a couple of seconds and then dies. Could this be an immobiliser problem?? How can i sort this out? What else could it be?? please help!!
Offline Rmachines
  • Passat 20vT Estate and Candy White MK3 1.8 GL
do you hear your fuel pump buzz when you switch the ignition on?
10 golfs and counting!
Engine cranes = the ultimate tool to test the tensile strength of Everything you didn't disconnect!
have you got a spare key? if so give that a go. also will it carry on running if you give it some throttle? also what engine code is it and what year
Offline dewmk3
hi, its a 97 mk3 gti 8v and the car stalls even if i give it some throttle and i can smell petrol after a couple of go's?? A m8 of mine tryed bypassing the imobiliser but the car wont start at all like this. If it was the ignition switch, I assume it wouldnt start at all?? Or do i have to get my key coded again or is it possible to do it myself??
« Last Edit: 12 October 2010, 22:24 by dewmk3 »
cant bypass the immob without sending the ecu away to have it defeated on these its built into the ecu.  you need to get vag-com on the car to find out exactly why it is kicking in. could be any number of things from immob box broken, reader coil failure to it loosing the key matching or its just lost power.  Reader coil would be 1st port of call if you really cant get it on vag com, you'll find em on any post-96 mk3 golf and loads of other vags from 96 onwards.
the keys are matched to the immob box under the dash, the matched box and keys are then coded to the ecu. if you get another immob box with matched keys you can swap this over then use vag-com to match it to your ecu. take the chip out of the supplied key(s) and fit to your old keys, jobn done.
watch out though the very late mk3s and later vags have a different immob box which has different plugs on. ideally check which plugs your old box has on it before you go out and buy a coil and/or box
Offline dewmk3
The immobiliser/alarm fob is a seperate unit on mine. Its a little key fob, that has one button and a red led on it. To start the car i have to turn on the ignition to the first click..... press the button on the fob and then turn the key to start the engine.
Does that mean its not the original immobiliser ?? If it is an after market immobiliser il try and find out what make/model it is tommorrow.
I will also try and get vag-com to see what comes up??
Thanks again for your help  .
« Last Edit: 13 October 2010, 23:46 by dewmk3 »
Yep aftermarket.
Offline DTGTI
On my 16V my does the same..... but if you give it some throttle it catches and runs.....
you have 2 immobilisers on your car, the aftermarket setup plus the one that is built into the ecu.  you need to get it on vag-com, that will tell you exactly why the factory immobiliser is kicking in. wrong key, faulty immob box, faulty reader coil, ecu communication failure etc
Offline DTGTI
ok cheers will get it checked
