Author Topic: Immobiliser problem!!! Car start but stalls straight away ??? help!!  (Read 2251 times)
sorry was talking to dewmk3!
if your car fires up if you give it throttle, its not the immobilser. your issue is somewhere else, on mine when it did this was down to the isv being bust. worth checkign for vac leaks and look at the wiring behind inlet to the idle switch and throttle position sensor, bakes hard and cracks up over time
Offline mk16valver
i had the same problem on my 16v and found out it was the crank sensor cables had cracked try that mate
