Author Topic: helpp pleasee  (Read 1838 times)
Offline tobybrennan
  • GL get out the way, and make way for a 16v anni
helpp pleasee
« on: 28 September 2010, 15:48 »
rightt...
i'll sit in my car start it up (not a problem)
but when its idleing it sound ticky inside the car and outside the car
any ideas what this could be?
pleasee
Offline tobybrennan
Re: helpp pleasee
« Reply #1 on: 28 September 2010, 17:02 »
anyone?
Offline dom
  • Back in a Mk4
Re: helpp pleasee
« Reply #2 on: 28 September 2010, 19:24 »
Tappets?
Offline Deano2711
  • 1992 VR6
Re: helpp pleasee
« Reply #3 on: 28 September 2010, 20:28 »
Offline tobybrennan
Re: helpp pleasee
« Reply #4 on: 28 September 2010, 21:34 »
im clueless sorry
someone tell me what these are and how to fix :P pleasee
Offline Paul86S2
Re: helpp pleasee
« Reply #5 on: 28 September 2010, 21:40 »
rightt...
Bomb  :grin: Or have you got a watch dog  :grin:
Tappets are most likely - they are the bits the cam presses to open the valves.
A good oil and filter change may help solve this. Some people recommend an engine flush or run the car with about a litre of ATF fluid (auto transmission fluid) in the oil for a few hundred miles before the oil change. Do your own research on the engine flush or atf fluid because there are lots of people recommending that this is good and plenty saying its bad.
New tappets are fairly cheap or you can clean up your old ones but a bit complex getting them out.
Paul
Offline tobybrennan
Re: helpp pleasee
« Reply #6 on: 28 September 2010, 22:05 »
okayy thanks paul
will take it into a vw garage and get it sorted tomorrow
Offline DubSociety
Re: helpp pleasee
« Reply #7 on: 29 September 2010, 10:34 »
Ticky, what do you mean?
My alternator was on its a way out a while back, and it made a sort of ticking noise. Now been replaced and all is silent again. Nothing but the sound of the engine running and exhaust grumbling.
Offline Len
Re: helpp pleasee
« Reply #8 on: 29 September 2010, 10:53 »
Put a screwdriver on the engine (rocker cover) and put an ear to the handle, the ticking should be louder if its the tappets.
If not then look for other culprits!
www.sas.org.uk
www.the-ace.org.uk
Offline DubSociety
Re: helpp pleasee
« Reply #9 on: 29 September 2010, 11:40 »
If that is indeed true, what a fantastic tip! Go try it ...
Wonder how many other cheap/free/clever tricks their are to figure out whats gone etc ...
