Author Topic: how to fit air filter  (Read 4888 times)
Offline stainesy
« on: 26 September 2010, 13:16 »
ok just bought a nice mk3 golf gti 8v in black
has standere3d air box fitted.
have a cone style filter i want to put on it.
i can just take off the air box but there is a box with wires going into the metal bit ataches to air box what doi do with that?
Offline dom
  • Back in a Mk4
Re: how to fit air filter
« Reply #1 on: 26 September 2010, 15:34 »
Don't bother with a cone filter unless your going to fit a proper heat shield. Otherwise you'll end up drawing in the warm air from the engine rather than the cold air from outside the car.
Offline AlexMozza
« Reply #2 on: 26 September 2010, 15:38 »
Drill the standard one and get a good panel filter :D
2001 Satria GTi
Mini 25 Special Edition 1984 998 :D
Formula 3 Mechanic
« Reply #3 on: 26 September 2010, 19:43 »
+100  :smiley:
Offline Dmonday
« Reply #4 on: 27 September 2010, 00:26 »
unless you relocate the cone'd air filter to somewhere in your bumper near a vent or something and use a less restrictive pipe, can't really imagine much of a gain from doing it on an 8v to be honest! on my 1.8 i much prefered a drilled air box, sounded pretty nice too! :)
Dan
Offline dlongmu
« Reply #5 on: 27 September 2010, 00:44 »
To be fully realistic, on as simple an engine as the 8v is, a cone filter/panel filter or whatever is going to make the square root of sod all difference without the engine being tuned up using cams/ecu fine tuning etc. and that goes for power losses also, heat soak won't kill your power drastically, but you'll certainly not notice any improvement outside of noise. Sheilding and routing a cold air feed are simple and effective fixes also. As for fitting, find out first if you have a Bosch or Hitachi MAF (the box with wires going into it), if its bosch you're in luck as you can pick up cold air intake kits compatible for 15 quid on ebay. If it's Hitachi custom is the only way to go unless you can find an adapter the correct size (Bosch have a square hole, Hitachi round as far as I can gather, the former is more widely supported). I had hitachi and custom made mine out of the joint in the airbox on one very sad bored and lonely night  :grin:
Offline MotorPsycho
  • I drive a 2000bhp dragster, so what ;)
« Reply #6 on: 27 September 2010, 09:21 »
can we have a sticky answering this question please?
the don't do it and ensuing reasons are starting to wear my keyboard out
kthnxbai
1983 mk1, 2.0, TSR pack C head, Eaton M45 - work in progress
1990 mk2 GTD, boost, fuel, soot
16v GTi mk3; chilli red, 16" Audi Speedlines, coilies
1934 Ford Dragster, 200mph in 6 seconds.
Offline AlexMozza
« Reply #7 on: 27 September 2010, 11:12 »
kthnxbai
LOL!
2001 Satria GTi
Formula 3 Mechanic
Offline Len
« Reply #8 on: 27 September 2010, 13:33 »
Can we please educate numpties in the art of using the SEARCH function before asking stupid repeat questions! :rolleyes:
www.sas.org.uk
www.the-ace.org.uk
Offline VR6_Wherry
« Reply #9 on: 27 September 2010, 14:05 »
kthnxbai
You mean like this one that's been here for over a year!!!
http://www.golfgtiforum.co.uk/index.php?topic=129025.0
 :grin: :grin:
