Author Topic: Engine Temp  (Read 2474 times)
Offline mrshakeyuk
  • Mods cost money, Smiles cost nothing
Engine Temp
« on: 16 September 2010, 16:40 »
Hi Guys
bit of advice please, and i have done a search and couldnt really find much on my problem i have if it is one.
My engine temp only gets to 90 when the car is ticking over. When i drive it the temp goes down and only rises when i stop with the engine ticking over?
should i be worrried about this?
Offline Lewisf1988-DUB
  • 1.8T AGU
Re: Engine Temp
« Reply #1 on: 16 September 2010, 16:47 »
cold air goes through the radiator when driving therefore cooling the engine, when sitting idle there is no cold air flowing hence the temp rise.
Offline Rhyso
Re: Engine Temp
« Reply #2 on: 16 September 2010, 16:48 »
Replace your thermostat
Car temp should sit bang on 90 degree once up to temperature
  • 1.8T AGU
Re: Engine Temp
« Reply #3 on: 16 September 2010, 16:56 »
mine goes below 90 when driving at 70mph for a while  :lipsrsealed:
Offline Rhyso
Re: Engine Temp
« Reply #4 on: 16 September 2010, 16:58 »
Then you got a fault  :tongue:
Offline T_J_G
Re: Engine Temp
« Reply #5 on: 16 September 2010, 17:06 »
A thermostat fault ;)
  • 1.8T AGU
Re: Engine Temp
« Reply #6 on: 16 September 2010, 19:05 »
Hmmm well I just changed my coolant sensor a couple of weeks ago cause there was a fault. I would have thought that, when driving at speed the cool air would cool the engine, only goes down to about 80ish
Offline richw911
Re: Engine Temp
« Reply #7 on: 16 September 2010, 19:16 »
Nope should stay at 90  :wink:
  • 1.8T AGU
Re: Engine Temp
« Reply #8 on: 16 September 2010, 19:25 »
So if I've changed the sensor, any suggestions? I ain't cleared the code since putting in the new sensor, my mate cleared it after he found it, but no doubt it's came back since then cause I waited at least a month before gettin the sensor. If the code ain't cleared would the fault still be causing a problem?
Offline vwfiend
Re: Engine Temp
« Reply #9 on: 16 September 2010, 19:33 »
To be fair, neuspeed sell a lower stat set at 80 so the engine maintains a cooler temperature......
