Author Topic: Engine Temp  (Read 2479 times)
Offline Rhyso
Re: Engine Temp
« Reply #10 on: 16 September 2010, 19:47 »
So if I've changed the sensor, any suggestions?
You've had two already  :rolleyes:
Replace your thermostat
A thermostat fault ;)
Offline Dan_GTI
  • GTi addict formally known as yoof
Re: Engine Temp
« Reply #11 on: 16 September 2010, 20:02 »
give the lad what he asked for... or do one back too club audi  :grin:
MK4 H&R 50MM SPRINGS FOR SALE £100 BRAND NEW
Offline northeast_gti-t
  • "1.8T AGU"
Re: Engine Temp
« Reply #12 on: 17 September 2010, 00:36 »
As said your thermostat needs replacing your sensor should be fine if you've not long changed it preferably with the o.e.m item tho and i would fit an o.e.m stat to and as winters approaching some new G12++ coolant too
2000 Mkiv GTi 1.8T AGU
Offline Lewisf1988-DUB
  • 1.8T AGU
Re: Engine Temp
« Reply #13 on: 17 September 2010, 01:09 »
ah so the temp sensor and the thermostat are different things? yea got an OEM one from VW, and i'll do a cooland change too. and reason why id use G12++ opposed to G12+? its an AGU if that helps
  • "1.8T AGU"
Re: Engine Temp
« Reply #14 on: 17 September 2010, 01:39 »
They certainly are and its worth getting it changed soon as the weather will be getting cooler soon the G12++ is afaik just an updated coolant so to speak to replace the earlier stuff some dealers may have stock of the older stuff i don't think it makes all that much difference it could be down to the fact of the make up of the coolant,inhibitors etc etc
  • 1.8T AGU
Re: Engine Temp
« Reply #15 on: 17 September 2010, 08:30 »
So how much is the thermostat gonna sting me? And where's it located?
Cheers for the help :)
Offline richw911
Re: Engine Temp
« Reply #16 on: 17 September 2010, 08:44 »
About £15 IIRC  :smiley:
Its is below the alternator.
http://www.golfgtiforum.co.uk/index.php?topic=101783.0
  • 1.8T AGU
Re: Engine Temp
« Reply #17 on: 17 September 2010, 09:45 »
Cheers rich, much appreciated. Yet another thing to buy :(
