Author Topic: Car Audio Problems  (Read 3684 times)
Offline Charge
  • Into Notion, Out of Motion
Car Audio Problems
« on: 25 August 2010, 11:08 »
Hey.
I have a JVC KD-R411 and wanted to use the USB slot to connect an external hard drive to it, but I really don't know how.
Normal connection it reads (cannot play), and I have tried formatting the HDD to FAT32 which apparently Radio's like more, but the drive is too big for that format (its 640) and NTFS doesnt work either. I dont even know what USB speed my Radio has. >.<
Anyone else had this problem at all?
Also, I am trying to fit door speakers to my pre90 mk2. Anyone know of any good fitters around the Yeovil area? Liquid Ice have disappeared/moved.
Thanks.
Offline jv
  • Administrator
Re: Car Audio Problems
« Reply #1 on: 25 August 2010, 12:13 »
http://www.jvcmobile.co.uk/documents/products/KD-R311%20312%20E.pdf
No mention of attaching anything other than usb memory sticks. The issue may well be that it does not provide enough power to run an external hard drive over the connection.
Buy site stuff!
GolfGTI.co.uk - merchandise
Support the forum charity!
Offline Charge
« Reply #2 on: 25 August 2010, 12:17 »
Thanks jv.
Does anyone run a HDD here? And what headunit they have?
It is a little annoying. I wanted all my music =[
Offline jv
  • Administrator
« Reply #3 on: 25 August 2010, 16:33 »
I guess an iPod is the obvious answer :tongue:
Buy site stuff!
Offline Charge
« Reply #5 on: 25 August 2010, 19:18 »
I have more, I recently bought a 640 to hold all my music (sitting at 260 and counting) and I absolutely hate Ipod/Itunes/Apple with a passion.
It worked, I partitioned the drive (320 FAT32 /320 NTFS) and it can now locate the smaller drive.
Now I just need a place to wire my speakers up properly, masking tape makes it all static!  :grin:
Offline DubSociety
« Reply #6 on: 27 August 2010, 14:02 »
I learnt from my mistakes.
Make sure you solder the connections on your door speakers, feed the wires to the boot, on to the amp, and again, use spade connectors ... these little things make all the difference. I get no distortion and can put my volume to MAX.
Offline Charge
« Reply #7 on: 27 August 2010, 23:35 »
I havent got an amp, just running the door speakers into the head unit, but not sure how to connect them to the original loom.
Offline DubSociety
« Reply #8 on: 28 August 2010, 10:13 »
Im guessing its not a simple ISO plug then? your going to have to look at the speaker wires on the speakers, or run new ones to behind the dash and feed it to the ISO plugs, once again with crimps. You'll have to figure out which wire is plus and negative, have a closer inspection on the wire it might even hint which is positive and neg. To be honest though, if you need to go through the hassle of feeding wires to the dash, just feed em all to your boot and get a cheap small amp for £20-£30 the sound will be hundreds times better!
Edit: once you hear amped door speakers/components you'll never go back! its an essential for any car I buy in the future ... a small 10" sub, with amped door speakers.
Offline Charge
« Reply #9 on: 28 August 2010, 12:11 »
Do you know any outlets that would do the setup for me for beans? (cheap)
