Author Topic: Boxster S rear calipers  (Read 8531 times)
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Boxster S rear calipers
« Reply #20 on: 21 August 2010, 00:59 »
Standard Boxster Calipers also have 130mm centers for mounting thats why so many early boxster owners upgrade to Boxster S Calipers...
Also you dont wanna buy RS2 Carriers either as they are a fortune... Look at these... I have them on my S2.. http://cgi.ebay.co.uk/ws/eBayISAPI.dll?ViewItem&item=260650623665
Better value and better quality....
Quote
clipperjay what diameter discs are those? over 300mm? apparently you canand you  use these calipers on a 280mm setup (which i have). point being i might get away with a smaller wheel...?  :huh:
Seat cupra turbo 304mm
I would be careful about smaller calipers from a standard boxster the mounting holes might be smaller for the RS2 carriers as long as they are match for your mount holes (Carrier bolt center holes end to end 13cm) they would be fine, but like I said I had a set of black ones and they didn't fit had to be Boxster S's rears
Seat, that’s a 12" or 28mm thickness-304 mm diameter 4 X 100 Seat Ibiza Cupra R 1,8 turbo on old platform ('00-'02  )  Seat Ibiza Cupra R
Discs 6KL 615 301 £52.48 ea
Pads 6KL 698 151 £60.17
These are Boxster’s rear part numbers for Callipers’.
996 352 421
996 352 422 are good
For More Info Click To See;
Offline clipperjay
« Reply #21 on: 21 August 2010, 11:38 »
Quote
996 352 421
It would work, but bet they are heavy........... The RS2 design are better and much lighter you get what you pay for LOL  :wink:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #22 on: 21 August 2010, 11:43 »
The RS2 ones are just a casting.. the other ones are machined alloy and are very light... I have a set on my S2!!
Most peeps on the S2 Forum like these better!!
Offline clipperjay
« Reply #23 on: 21 August 2010, 11:48 »
Well if he wants to go down the route guess its all good!
If the RS2 chaps like them better, then there should be loads of RS2 spare carriers going cheap then? :wink:
