Author Topic: Boxster S rear calipers  (Read 8530 times)
Offline clipperjay
Re: Boxster S rear calipers
« Reply #10 on: 19 August 2010, 01:37 »
Yes G60 Master CYL will be fine!
The Alloy clearance must be ET38 or ET37.5 (Rare LOL).
Compomtive was the only smaller alloy with an oval shape hub clearance under 16!
Offline cняis
« Reply #11 on: 19 August 2010, 13:28 »
sounds like i'd have issues with 15" ET35 MIMs then
well the 280mm setup works great at the moment so i will bear all this in mind
Offline clipperjay
« Reply #12 on: 19 August 2010, 19:08 »
Chris you judge have a look at my alloys both 17" are ET38! Not much room non?
Offline Neo Badness
  • Feet are for pedals
« Reply #13 on: 19 August 2010, 21:26 »
That will be a tasty setup, what size are the new calipers?
Is the G60 M/c and servo bigger than say a 16v? 22mm and 9" respectively?
Offline Adam
« Reply #14 on: 19 August 2010, 21:44 »
Don't suppose you know 'Flash' around Yeovil quite a bit, he drives a white mk2 BAM lump? He has brembo 4pots under quite a small wheel.
Down Hill From Here.
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #15 on: 19 August 2010, 23:23 »
If you can get a set the "Standard Boxster" Calipers thay are Smaller than the Boxster S Ones...
986 Boxster Fronts...  986-351-421/422
986 Boxster Rears...  986-352-423/424
Front & Rears are the same size but pistons are smaller on the rears....
For More Info Click To See;
Offline cняis
« Reply #16 on: 20 August 2010, 00:18 »
yes I dont know the chap but ive seen him (apparently) in ilchester (when someone posted on here about a stolen white mk2 from ilchester).
also this evening I saw an old maroon polo saloon on what i assume were ats wheels (with massive stretch) and a slammed red polo 6n2 or 9n(?) hanging about in the same area!
anyway i digress.
i think the boss has realised the cost of new rear calipers for his pansy boxster S, so there goes my brake upgrade  :angry:
clipperjay what diameter discs are those? over 300mm? apparently you can use these calipers on a 280mm setup (which i have). point being i might get away with a smaller wheel...?  :huh:
Offline Neo Badness
« Reply #17 on: 20 August 2010, 00:25 »
Tell your boss to stop being such a ghey, if he doesn't get new rear brakes the people will question his sexuality even more etc etc.
 :grin:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #18 on: 20 August 2010, 10:07 »
What colour are his?
As I have a pair of Like New Black ones..
and a pair of Reds that in Superb Condition.... :wink:
Offline clipperjay
« Reply #19 on: 21 August 2010, 00:45 »
Quote
Seat cupra turbo 304mm
I would be careful about smaller calipers from a standard boxster the mounting holes might be smaller for the RS2 carriers as long as they are match for your mount holes (Carrier bolt center holes end to end 13cm) they would be fine, but like I said I had a set of black ones and they didn't fit had to be Boxster S's rears
Seat, that’s a 12" or 28mm thickness-304 mm diameter 4 X 100 Seat Ibiza Cupra R 1,8 turbo on old platform ('00-'02  )  Seat Ibiza Cupra R
Discs 6KL 615 301 £52.48 ea
Pads 6KL 698 151 £60.17
These are Boxster’s rear part numbers for Callipers’.
996 352 421
996 352 422 are good
