Author Topic: Boxster S rear calipers  (Read 8535 times)
Offline cняis
« on: 18 August 2010, 20:01 »
Anyone know if you can use Porsche Boxster S (2003) rear calipers on a mk2 (front)?  :huh:
Offline X4MGS
  • VAG Parts SNOB!!!
Re: Boxster S rear calipers
« Reply #1 on: 18 August 2010, 20:09 »
Yes BUT you need BIGGER alloys to fit em under... 17's I Think...
http://www.s2forum.com/forum/showthread.php?t=45998
I asked the same question...
For More Info Click To See;
Offline cняis
« Reply #2 on: 18 August 2010, 20:23 »
even for using rear calipers?  :huh:
my boss has a boxster S with paint peeling off the rear calipers... he told me today he was buying a new set purely because the paint was coming off! so i may make an offer on the old set, will be cheap  :smug:
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #3 on: 18 August 2010, 20:26 »
Yes eaven rears.. they are not that much smaller then the fronts...
If you don't buy 'em I would be interested at the right price!!
Offline cняis
« Reply #4 on: 18 August 2010, 22:51 »
Ok i'll let you know, the 280mm setup works fine but it doesnt hurt to have more braking power!
I have a G60 master cylinder, would this be enough for a porsche caliper setup?
Offline cняis
« Reply #5 on: 18 August 2010, 22:57 »
according to that thread, you can use certain 15" wheels, so i might be ok. Also they mentioned 280mm discs :afro:
Now, how do i go about carriers....? im guessing theyd need fabricating?
Offline myvr6isarocket
« Reply #6 on: 18 August 2010, 22:59 »
You speak to me and i fabricate and heat treat them in the workshop for a token payment
Offline cняis
« Reply #7 on: 18 August 2010, 23:09 »
:afro: i'll get in touch, if the boss's pockets are deep enough for new rear calipers, i'll be having the old ones
« Reply #8 on: 18 August 2010, 23:15 »
Could probably sand-cast them for you if we can make a female mould on the vacuum former. Anything is possible
Offline X4MGS
  • VAG Parts SNOB!!!
« Reply #9 on: 19 August 2010, 00:17 »
I think Volkpartz already do one..
