Author Topic: trim: what are these and where do I get them?  (Read 2989 times)
Offline javalin
« on: 02 August 2010, 19:24 »
Hiya
As topic - sticky fabric'y things that go behind the mid-level door trim on the GTI
Ordered trim fixings from VW today, but didn't see these.
James
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline harlemex
Re: trim: what are these and where do I get them?
« Reply #1 on: 02 August 2010, 21:32 »
looks like a velcro attatchment that somebody has stuck on there, maybe totake place of a broken clip.
Offline Deano2711
  • 1992 VR6
« Reply #2 on: 02 August 2010, 21:34 »
Agreed....certainly not something VW would put on the car.
Offline javalin
« Reply #3 on: 03 August 2010, 09:11 »
disagree - they cover up a hole (manufactured like that) in the panel and presumably are there for water proofing.  I will ask VW when I collect othe fittings.
Cheers,
James
« Reply #4 on: 03 August 2010, 09:46 »
Cheers,
James
Someone has stuck them on, mine had the holes as well
Offline Deano2711
  • 1992 VR6
« Reply #5 on: 03 August 2010, 10:10 »
Cheers,
James
If your guy from VW sells you any of these at stealer rates then trust me you WILL have been conned. I have removed the trim before (as has Wayne) and these are not fitted as standard. The little clips are the only standard fixings on trim.
Offline VR6_Wherry
« Reply #6 on: 03 August 2010, 10:32 »
+ 1 they are not standard, or if they are they are very rare! I've never come accross them in the cars i've help broke..
Looks rather clean for a car over 12 years old!
Offline archie837
« Reply #7 on: 03 August 2010, 10:43 »
Had my trim off and never seen anything like that. Just the holes for the plugs to go in
Project longterm Airbanger.
PD150 Anni daily
Offline javalin
« Reply #8 on: 03 August 2010, 12:12 »
interesting....
Any suggestions where to get them from?  One has come off, so needs to be replaced to keep it water tight.
:smiley:  Trim was removed for clay, polish and wax.  Also a previous owner has had it re-sprayed.
J
« Last Edit: 03 August 2010, 12:18 by javalin »
« Reply #9 on: 03 August 2010, 13:10 »
They are not factory so god knows where to get them.
