Author Topic: trim: what are these and where do I get them?  (Read 2991 times)
Offline VR6_Wherry
Re: trim: what are these and where do I get them?
« Reply #10 on: 03 August 2010, 13:28 »
interesting....
Any suggestions where to get them from?  One has come off, so needs to be replaced to keep it water tight.
>Looks rather clean for a car over 12 years old!
:smiley:  Trim was removed for clay, polish and wax.  Also a previous owner has had it re-sprayed.
J
Sorry what i meant is, if the fabric was standard on the cars it looks very clean for it's age!
If it's had a respray before then you can be pretty certain it was put on by the previous owner.
Offline Len
« Reply #11 on: 03 August 2010, 15:43 »
Definitely NOT standard. And no need for them.
www.sas.org.uk
www.the-ace.org.uk
Offline archie837
« Reply #12 on: 03 August 2010, 17:09 »
Keep it watertight? Is there a big hole in your door?
Project longterm Airbanger.
PD150 Anni daily
Offline javalin
« Reply #13 on: 03 August 2010, 18:20 »
there is a hole in the panel behind the sticky thing.  It looks to be a manufactured hole rather than damage.
You only ever need two tools in life. If it moves and it shouldn't use Duct Tape. If it does not move and it should, use WD40.
Offline javalin
« Reply #16 on: 03 August 2010, 20:07 »
to keep the door from filling up with water maybe?
« Reply #17 on: 03 August 2010, 20:09 »
Yes but they are open from the factory, for some reason.
That sticker will not stop the water anyway over time it will peel
Offline javalin
« Reply #18 on: 03 August 2010, 20:22 »
how very odd.  surely rain water will run down the door, into the door then out of the door drain?
James
« Reply #19 on: 03 August 2010, 20:30 »
James
Maybe they did it like that so water will stay stuck behind the moulding.
