Car audio
amp problems
Topic: amp problems (Read 3725 times)
lil rich
amp problems
23 July 2010, 17:50 »
Wired up my amp to my 6x9's and head unit now when i turn the engine on i have a nasty whine noise comin out from 6x9's.
seperated the power from the rem lead and made sure i have a perfect earth! any other ideas?
DUBBEDMK3
dubbed mk3
Re: amp problems
14 August 2010, 19:00 »
you want to get on ebay mate and get a ground loop isolator its the balls had the same problem in my mk3 for a while and it fixed it cheap as chips too
troublestarter
Re: amp problems
15 August 2010, 08:23 »
firstly have you run your rca cable down the same side of the car as the amp power cable
if yes the that will more than likely be the problem signal and power cables should ideally be run down opposite sides of the car
also where is your amp earth mounted
this needs to be a good solid and bare metal point
also it could even be the gain level on the amp is too high!!!!
www.awesomeautomotive.co.uk
<br />mobile vehicle security & audio fitting service<br />insurance accredited
mattyass
GTI forum regular
Re: amp problems
16 August 2010, 10:57 »
Thought i would jump in on this thread as i have been experiencing the same problem. Installed my amp into my mk3 yesterday and i am now getting engine sounds/whine through the speakers. Made sure rca and power cables ran down opposite sides. Used a seatbelt bolt above the rear wheel well as an earth and made sure the gain level was right down but still got the problem. Dos anyone have any more advice on this???
troublestarter
Re: amp problems
16 August 2010, 11:44 »
matty try plugging in another rca
mattyass
GTI forum regular
Re: amp problems
16 August 2010, 11:56 »
You mean a whole new cable? The one i used was brand new. There are two sets of connections in the back of the Hu though. Could swap those?
dragonfly
Re: amp problems
16 August 2010, 12:55 »
Try another cleaner earth point (no paint).
mattyass
GTI forum regular
Re: amp problems
16 August 2010, 14:01 »
May try a different earth tonight.The one im using seems ok and i did sand back the area to bare metal. Still may be worth trying somewhere else.
DUBBEDMK3
dubbed mk3
Re: amp problems
18 August 2010, 21:48 »
im telling you lol ground loop isolator
DubSociety
Re: amp problems
22 August 2010, 11:01 »
Don't mean to high jack but I get a headunit turn on thump/pop, and when I change track subwoofer pop. Never got this and I had my setup for over 3 years. It started happening after I disconnected my sub to access my fuel sender.
Car audio
amp problems
