Author Topic: amp problems  (Read 3680 times)
Offline lil rich
amp problems
« on: 23 July 2010, 17:50 »
Wired up my amp to my 6x9's and head unit now when i turn the engine on i have a nasty whine noise comin out from 6x9's.
seperated the power from the rem lead and made sure i have a perfect earth! any other ideas????
cheers
Offline DUBBEDMK3
  • dubbed mk3
Re: amp problems
« Reply #1 on: 14 August 2010, 19:00 »
you want to get on ebay mate and get a ground loop isolator its the balls had the same problem in my mk3 for a while and it fixed it cheap as chips too
Offline troublestarter
Re: amp problems
« Reply #2 on: 15 August 2010, 08:23 »
firstly have you run your rca cable down the same side of the car as the amp power cable
if yes the that will more than likely be the problem signal and power cables should ideally be run down opposite sides of the car
also where is your amp earth mounted
this needs to be a good solid and bare metal point
also it could even be the gain level on the amp is too high!!!!
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline mattyass
Re: amp problems
« Reply #3 on: 16 August 2010, 10:57 »
Thought i would jump in on this thread as i have been experiencing the same problem. Installed my amp into my mk3 yesterday and i am now getting engine sounds/whine through the speakers. Made sure rca and power cables ran down opposite sides. Used a seatbelt bolt above the rear wheel well as an earth and made sure the gain level was right down but still got the problem. Dos anyone have any more advice on this???
Re: amp problems
« Reply #4 on: 16 August 2010, 11:44 »
matty try plugging in another rca
Offline mattyass
Re: amp problems
« Reply #5 on: 16 August 2010, 11:56 »
You mean a whole new cable? The one i used was brand new. There are two sets of connections in the back of the Hu though. Could swap those?
Offline dragonfly
Re: amp problems
« Reply #6 on: 16 August 2010, 12:55 »
Try another cleaner earth point (no paint).
Offline mattyass
Re: amp problems
« Reply #7 on: 16 August 2010, 14:01 »
May try a different earth tonight.The one im using seems ok and i did sand back the area to bare metal. Still may be worth trying somewhere else.
Offline DUBBEDMK3
  • dubbed mk3
Re: amp problems
« Reply #8 on: 18 August 2010, 21:48 »
im telling you lol ground loop isolator :huh:
Offline DubSociety
Re: amp problems
« Reply #9 on: 22 August 2010, 11:01 »
Don't mean to high jack but I get a headunit turn on thump/pop, and when I change track subwoofer pop. Never got this and I had my setup for over 3 years. It started happening after I disconnected my sub to access my fuel sender.
