Author Topic: my mk2 abf track car  (Read 58529 times)
Offline leeroy20vt
  • h reg mk2 gti
« on: 22 July 2010, 09:31 »
as a few of know i started with a mk3 8v tbh its was pants for the track i think anyway
so i had a 1.3 mk2 non sunroof 3dr laying about we had bought to do it up and sell but it didnt happen so i set about finding a 16v mk3 complete and stripped that to wide track and abf the mk2
would like to say huge thanks to rubjonny
will update in a bit with pics ect
« Last Edit: 01 January 2012, 16:10 by leeroy20vt »
Offline leeroy20vt
  • h reg mk2 gti
Re: my new track sl@g
« Reply #1 on: 22 July 2010, 19:37 »
rite some pics
sort of from the start
the old wiring loom out of the mk3 16v all taged up so i didnt forget what was what
the mk2 in question
old 1.3 out state of the bay
old fuel tank on the way out and rear beam
mk3 tank in
rear beam on
Offline leeroy20vt
  • h reg mk2 gti
« Reply #2 on: 22 July 2010, 19:42 »
wiring loom stripped with much help from rj
engine bay a little cleaner
power plant
front subframe in
wiring loom put in car and all in place ish lol
tada!!!!!!!!!!!!
Offline leeroy20vt
  • h reg mk2 gti
« Reply #3 on: 22 July 2010, 19:47 »
yesterday was a learning curve mk2 manual rack with new tierods/ends fitted on really easy put the 8v rod change box on not so sure the mk3 gti clutch cable is goin to work tho seems abit short
engine was put in today and is now running just need to sort a exhaust out
some seats i picked up yesterday
and a cople of pics of the interior
so this is how i left her tonight
still alot to do tidying wires ect fitting radiator and sort the seats so they fit
all in all not a bad week or so
« Last Edit: 22 July 2010, 19:53 by leeroy20vt »
Offline cняis
« Reply #4 on: 22 July 2010, 20:42 »
looking good :afro:
« Reply #5 on: 22 July 2010, 20:42 »
Cracking progress
Offline Diamond Hell
  • Opinions я Us
« Reply #6 on: 22 July 2010, 22:31 »
Think you're going to be out of luck there.  The 8V G3 GTI, which has an 020 box uses a larger input shaft than the G2 GTI, so if you've used a G2 gearbox and a G3 8V GTI clutch you're not going to have any drive.
Why aren't you using the 16V cable-shift gearbox?  Unless you've bolted the 020 diff you're going to have a failed gearbox on your hands shortly.
Have you re-lined the brake system with new hard lines?  If so, have you fitted a compensator on the rear beam?
If not, you'll need one.  If you've not finished to system I'd recommend wiring it up different to standard, with a manual bias valve and with the front brakes on separate ports out of the master cylinder.
Time to get all that trim out now  :grin:
Offline leeroy20vt
  • h reg mk2 gti
« Reply #7 on: 22 July 2010, 22:36 »
the box was out of the 8v mk3 i had havent used the 16v box as need to find a pedal box from a corrado or passat
was goin to fit manual compensator iether in the car or under the bonnet just got to find one
i take it the brake are split at the mo then one hole on master does one side and other hole does other side ?
Offline fishnchipsx2
« Reply #8 on: 22 July 2010, 22:50 »
Looking good!
Should be split diagonally from corner to corner as standard
Offline Horney
« Reply #9 on: 22 July 2010, 22:52 »
Good work mate!
Nick
