Author Topic: Changed Spark Plug & Coil Pack-But still have missife on Cylinder 2,What Next ?  (Read 12749 times)
Offline johnford60
  • MK7 GTD 3 Door
Hi,
I had a missfire on cylinder 2 when running live data on Vag com. Change Spark Plug & Coil pack, but still have missifre on cylinder 2?... Ive tried swapping coil packs and spark plug round to another cylinder, but still have missifire on cylinder 2 !!! :undecided:
What's next to check or change?
John
Offline moutains
get a compression test done it could be a burnt out valve
Offline bacillus
Could be a bad injector...
Without traction power is nothing!
Offline stevieC
This happened to mine after a revo remap,missfire on cylinder 2.Changed coil pack & plugs but this didnt fix it,ended up replacing the ecu.
Gtd 3dr candy white,charleston shadows
Offline winrya
when i was looking for solutions to my cylinder 2 misfire guy at garage said he'd just done a leon and they had to replace the injector.  Part was around £120 but said was a really big job to change it
Offline Hurdy
Could be the injectors. They are a PITA to get to as they are under the intake manifold.
I haven't heard of valves burning out before on K03 GTI's, but you never know.
Seat Leon Cupra Black 290 DSG
Offline johnford60
  • MK7 GTD 3 Door
Thanks for replies,
I've done some more data logging on vag com tonight, and i managed to get miss fire on cylinder 2 , 3 & 4 now!...
Its not all the time, just at random times, Also still have Low boost fault tat occurs!!
I've changed so far:
DV ( By VW On warranty 3 months ago )
PCV
Coil Pack
Maf Sensor
Turbo Boost Solenoid  ( The one with 3 vacuum hoses too )
Change spark plugs around ( These have done 8,000 miles )
Help Me  :rolleyes:
John
Offline bacillus
Common Misfire sources:
Bad or Incorrect Spark Plugs
Bad or Incorrect Spark Plug Gap
Bad or Incorrect Coil Packs
Injectors with high levels of buildup
Heavy buildup on valves
Bad or Incorrect Exhaust Valve Springs
Bad Exhaust lasher/rocker assemblies
Damaged O2 sensor
Damaged MAF sensor
Incorrect MAF housing
Heavy Turbulence over MAF housing
Bad or Incorrect High Pressure Fuel Sensor
Bad or Incorrect Low Pressure Fuel Sensor
Bad High Pressure Fuel Pump
Bad Low Pressure Fuel Pump
Bad or Incorrect Low Pressure Fuel Pump Pulse Width Modulator
Bad, Dirty or Incorrect Fuel Filter
Damaged High Pressure Fuel Pump Cam Lobe
Bad Evap Purge Valves
Leaking PCV system
Excessive fuel/oil vapors pouring into intake track
Offline johnford60
  • MK7 GTD 3 Door
Ok i've done a global scan of all control module's and have a load of random fault codes??:
I Mean, What the hell!!!! :cry:
Address 02: Auto Trans        Labels: 02E-300-0xx.lbl
   Part No SW: 02E 300 042 M    HW: 02E 927 770 AD
   Component: GSG DSG         041 0824
   Revision: 04004010    Serial number: 00000504090152
   Coding: 0000020
   Shop #: WSC 01279 785 00200
   VCID: 1D3ADA2ABDD9
1 Fault Found:
18258 - Powertrain Data Bus: Missing Message from ECU
            P1850 - 000 -  -  - Intermittent
Address 03: ABS Brakes        Labels: 1K0-907-379-MK60-F.lbl
   Part No: 1K0 907 379 K
   Component: ESP FRONT MK60      0104
   Coding: 0004738
   VCID: 3A7031B60C37
2 Faults Found:
01314 - Engine Control Module
            013 - Check DTC Memory - Intermittent
            004 - No Signal/Communication - Intermittent
Address 08: Auto HVAC        Labels: 1K0-907-044.lbl
   Part No: 1K0 907 044 AF
   Component: ClimatronicPQ35 066 0505
   Shop #: WSC 00000 000 00000
   VCID: 6BDEC4F233ED
1 Fault Found:
Address 09: Cent. Elect.        Labels: 3C0-937-049-23-H.lbl
   Part No SW: 1K0 937 049 N    HW: 1K0 937 049 N*
   Component: Bordnetz-SG     H37 0803
   Revision: 00H37000    Serial number: 00000001773309
   Coding: E58D0F0601041800001400001400000000087F075C
   VCID: 3A7031B60C37
   Part No: 1K2 955 119 B
   Component: Wischer VW350  012  0401
   Coding: 00065493
   Shop #: WSC 00000
   Part No: 1K0 955 559 M
   Component: RegenLichtSens 005  0605
   Coding: 00152613
   Shop #: WSC 00000
2 Faults Found:
01049 - Supply Voltage Term 50
            006 - Short to Plus - Intermittent
Address 17: Instruments        Labels: 1K0-920-xxx-17.lbl
   Part No: 1K6 920 970 E
   Component: KOMBIINSTRUMENT VDD 0810
   Coding: 0001403
   Shop #: WSC 00066 210 52663
   VCID: 32601996D447
1 Fault Found:
Address 19: CAN Gateway        Labels: 1K0-907-530.lbl
   Part No SW: 1K0 907 530 E    HW: 1K0 907 951
   Component: Gateway         H11 0110
   Revision: 11          Serial number: 29001054210979
   Coding: 3F0F0342070001
   VCID: 2952FEFAF991
1 Fault Found:
             Freeze Frame:
                    Fault Status: 00100100
                    Fault Priority: 2
                    Fault Frequency: 1
                    Reset counter: 144
                    Mileage: 150202 km
                    Time Indication: 0
                    Date: 2000.00.00
                    Time: 17:52:25
Address 44: Steering Assist        Labels: 1Kx-909-14x.lbl
   Part No: 1K2 909 144 K
   Component: EPS_ZFLS Kl.5   D06 1701
   VCID: 346C1F8E2E53
1 Fault Found:
             Freeze Frame:
                    Mileage: 160 km
                    Temperature: 55.0°C
                    Voltage: 12.20 V
                    Voltage: 12.00 V
Address 47: Sound System        Labels: 3C0-035-456.lbl
   Part No: 1K6 035 456
   Component: 08K Audioverst.     0003
   Revision: 00002000    Serial number: 00000000018553
   VCID: E9D23EFAB911
2 Faults Found:
00876 - Treble Speaker Rear Left (R14)
            006 - Short to Plus
00877 - Treble Speaker Rear Right (R16)
            006 - Short to Plus
John
Offline topher
  • Administrator
  • fully functioning
those just point to the battery being disconnected or going flat
