Author Topic: Changed Spark Plug & Coil Pack-But still have missife on Cylinder 2,What Next ?  (Read 12752 times)
Offline johnford60
  • MK7 GTD 3 Door
those just point to the battery being disconnected or going flat
Yea could be 1 option, BUT...
The battery has not been off and is not flat!.. Ive tested battery & alternator and is fine. Im getting different faults arising all the time!!!
John
Offline Hurdy
 An intermittent fault could point to a dry connection in the ECU, a poor wiring connection or a core break inside a wire. Have you disconnected any circuit connectors or wiring recently (or the dealer?)
Seat Leon Cupra Black 290 DSG
Offline johnford60
  • MK7 GTD 3 Door
I was thinking ECU  :cry:
I might take it off and send it to BBA for testing and repair, or is there another way to test?
Nothing's been disconnected before the faults occurred
Also my low boost fault i'm thinking could be the vanes stuck in my turbo as everything has been replaced that could be a possible cause!. Ive seen a turbo cleaning set for it?
John
Offline johnford60
  • MK7 GTD 3 Door
Been in VW for 3 Days now, and they cant find whats wrong!!...
John
Offline Holepunch
Keep us updated, mine was supposed to go in today but due to a cock up it will now have to wait till next week
« Last Edit: 05 August 2010, 14:24 by Holepunch »
Offline Ed30DSG
  • Edition 30 - gone - Audi S3 here
LOL, that doesn't suprise me one bit. You need to take it to a specialist. Sounds like its under warranty though - good luck.
p.s. the petrol GTi's don't have variable vanes on either K03 or K04 turbos, so unlikely to be that.
Offline johnford60
  • MK7 GTD 3 Door
What specialist?. Im Maidstone,Kent.
VW told me to pick it up today cause they couldn't find anything wrong!!...
John
Offline Hurdy
If it is registering misfires then there is definitely something wrong!
Offline johnford60
  • MK7 GTD 3 Door
I took for a blast tonight, and didnt feel too bad. I cant hear the turbo though to be honest with windows up, just alot of engine revving. It feel's like it did before when the DV went wrong!!.
....anyway, got home and sat in it for 2 mintues, and i could feel the engine miss-fire  :sad:. It's crap, How the hell can I diagnose a miss-fire with and without my vag com, and VW have it for 4 days and cant find a thing wrong with it.
Now what to do!!
John
Offline johnford60
  • MK7 GTD 3 Door
Someone recommended to change the Fuel pump in the tank!.
So ive done that today, and seemed to go good on the way home. I'll go for a blast tonight and update.
John
