Author Topic: Auto tailgate  (Read 8848 times)
Offline countrytrucker
Auto tailgate
« on: 14 July 2010, 13:45 »
I see SteveP has the auto tailgate mod on his golf.
Is this easy to do? Are there different rams required?
I love my GTD
Offline sundaydriver
Re: Auto tailgate
« Reply #1 on: 14 July 2010, 16:02 »
I remember reading a while back about this mod about issue's with the struts rubbing against the bodywork and leaving marks.
2012 Golf R, APR STAGE 2+, BCS power valve TB exhaust, loba HPFP, evoms intake, Rising blue, 19" Talladegas -BMW M2
Re: Auto tailgate
« Reply #2 on: 14 July 2010, 16:07 »
That doesn't sound too good! I tried searching for it but couldn't find anything  :huh:
I love my GTD
Re: Auto tailgate
« Reply #3 on: 14 July 2010, 16:12 »
Offline Dawnskaybug
  • GoAPR.co.uk
Re: Auto tailgate
« Reply #4 on: 14 July 2010, 19:42 »
I did mine you just flip the mounts.
No rubbing issues but it usually only works if its hot out..
APR K04//APR Carbonio Intake//Hawk HPS pads//Adams Rotors//Billy Banks Downpipe//APR Rear Sway bar
Offline PenguinGTI
Re: Auto tailgate
« Reply #5 on: 14 July 2010, 23:30 »
Any chance of some more details or ideally a guide how to?
thanks alot
I'm going to have a little look tomorrow based on this video http://www.youtube.com/watch?v=b3rINjv5aKw&NR=1
I don't fancy forking out for new parts so going to see if a tweak of the original parts works  :smiley:
« Last Edit: 14 July 2010, 23:43 by PenguinGTI »
Offline PenguinGTI
Re: Auto tailgate
« Reply #6 on: 15 July 2010, 11:25 »
Right I had a look this morning. The system operates with 2 parts: a strut and a mounting plate. It is easy to remove both parts so if anyone wants to do it it should be a fairly successful effort.
Simply turning around the OEM plates with the OEM struts is not enough to achieve the result I desired. You have to lift the tailgate yourself a couple of inches and then the struts take over and it continues itself. It is easier, but not easy enough  :grin:
I would also add that it makes the tailgate harder to shut. For this reason I consider turning the mounting plates to not be that efficient.
I am now going to order the skoda parts. The part number is 6YO 827 550 C for those that are interested. You have to order them from a Skoda parts department. VW didn't have a clue when I phoned them  :grin:. Anyway the struts are £16 each roughly so the total cost of the mod should be about £32.
I'm going for it. Parts should be in on saturday morning
Hope that helps  :smiley:
« Last Edit: 15 July 2010, 11:41 by PenguinGTI »
Offline SteveP
Re: Auto tailgate
« Reply #7 on: 16 July 2010, 08:10 »
I have reverted mine back to standard as after a while it starts to push the bootlid out when closed, so you get a gap around the sides when closed. It also means the bootlid does open as much so I kept hitting my head on the lid  :laugh:
I also found still (even with the skoda struts) when the weather is a little cold it won't open on it's own. I had no rubbing issues on the side of the paintwork.
If anyone wants the skoda struts to try drop me a PM as you can have them for £15 posted  :smiley:
Re: Auto tailgate
« Reply #8 on: 16 July 2010, 08:57 »
I think I will leave it after hearing your stories.
Thanks for saving me the hassle!
I love my GTD
Offline PenguinGTI
Re: Auto tailgate
« Reply #9 on: 16 July 2010, 14:00 »
Steve, what do you mean by it starts pushing out after a while? Do you mean the whole tailgate has a gap, or just at the top, or just at the bottom?
Also how long is a while?
PS. wish you had offered the struts yesterday before I went and ordered them from Skoda  :sad:
Ah well,
