Author Topic: 1.8 16v on abf managment yes or no help me pls  (Read 6529 times)
Offline barnysGTI
« on: 12 July 2010, 17:31 »
ok you may no that i've just got a mk2 with a 2.0 16vabf lump in it and now i've found out that it is ceased
wot i need to no is that can i use a mk2 1.8 16v lump on the abf managment.......?????????? all i'll b wanting to use is the head and block and bolt up eveything else that is in my engine bay...... use the mk3 box and wide track thats there n exhaust etc
wot issues is there or can i bolt it in and it will be ok??????
just that i can get my hands on the engine
its all about v dubs baby!!!!!!!!!!
Offline The Mighty Elvi
  • I'm better than you today.
Re: 1.8 16v on abf managment yes or no help me pls
« Reply #1 on: 12 July 2010, 19:12 »
seize  (sz)
v. seized, seiz·ing, seiz·es
2.
a. To cohere or fuse with another part as a result of high pressure or temperature and restrict or prevent further motion or flow.
cease (sēs)
transitive verb, intransitive verb ceased, ceasing ceas′·ing
to bring or come to an end; stop; discontinue
NO
No is an English/Old English word indicating rejection, disagreement, refusal or making a negative response or exclamation. In most cases, it is the opposite of yes.
know/nō/Verb
1. Be aware of through observation, inquiry, or information.
2. Have knowledge or information concerning
N.B.
Diamond Hell is away.
Offline barnysGTI
« Reply #2 on: 12 July 2010, 19:18 »
sorry for the short hand and spellin mistake no one is perfect!!!!!!!!!
Offline fishnchipsx2
« Reply #3 on: 12 July 2010, 19:51 »
Thinking aloud here, because I'm not that familiar with KRs, but AFAIK...
-No crank position sensor
-No knock sensors
-Different injectors (seats can probably be swapped about tho)
Offline danny_p
« Reply #4 on: 12 July 2010, 21:50 »
it can all be bolted up in theory,   use polo cranck sensor that goes behind flywheel, find hles for knock sensors and use abf inlet,   easy
all the VW's have gone bar 1.
Offline cняis
« Reply #5 on: 12 July 2010, 22:11 »
yeh but danny_p you make everything sound easy!  :grin:
Offline barnysGTI
« Reply #6 on: 12 July 2010, 22:36 »
lol so it can b done then?????
so cant i use the crank sensor off the abf engine then????
is that all there is to it.
just that i was thinking that there the same and only different was one is a 1.8 and the other is a 2.0 ok i cant use the 2.0 head as the cams would be different.
take it i would need to use the 1.8 injectors to???????
Offline Diamond Hell
  • Opinions я Us
« Reply #7 on: 12 July 2010, 22:54 »
No, you bolt on the ABF inlet and injector rail.
Because of the way the ABF management works it'll probably cope with a loss of 200cc, although it seems foolish to waste good management on a 1.8 motor....
Thanks for sharing the load.
Offline Neo Badness
  • Feet are for pedals
Offline danny_p
« Reply #9 on: 12 July 2010, 23:54 »
ask me about renults or writeen english then.
