Author Topic: Suspension trouble  (Read 2654 times)
Offline Neel
Suspension trouble
« on: 13 December 2004, 21:52 »
Hello.
Well my vw golf 1.3 is leaning to the drivers handside.There doesn't appear to be any damage to the coils or shocks.Has anyone ever had this problem?
What can be done?
Thanks.
vw 89 mk2 1.3
Veedubgt18v
Re: Suspension trouble
« Reply #1 on: 13 December 2004, 22:25 »
i suspect you got a worn/faulty spring get a new front pair and fit them see what happens. how much is it leaning?
Offline Neel
« Reply #2 on: 13 December 2004, 22:36 »
well i would say a good bit. its about 3cm down on one side.
I noticed it today.bought the car over the weekend so im not realy used to all the parts in the thing.
How can a spring get worn? does it just drop down?
Offline Helios_Blue_Valver
« Reply #3 on: 13 December 2004, 22:41 »
No to be a wise ar5e but was the last owner a really big person? I bought a car once that was owned by a bloke that was about 22 stones and it had a serious lean to the right.
Yours could be bumpstops and top mounts though.  :undecided:
Blue MK2
« Reply #4 on: 13 December 2004, 22:43 »
probably blown shocks. had this problem with mine when i bought it.
top mounts will probaby need a change aswel
EDIT: mine was lowered badly, thats why the shocks blew up and sat in a wierd angle :grin:
« Last Edit: 14 December 2004, 00:54 by Blue MK2 »
Veedubgt18v
« Reply #5 on: 13 December 2004, 22:46 »
shocks dont keep the car up tho. if you took the springs out it would be on the deck! i reckon springs. get a garage to look at it if you arent sure/confident/dont know
Offline Neel
« Reply #6 on: 13 December 2004, 22:51 »
i bought it from some dodgy dealer for very cheap.well the back is soft when i go around corners.I had a peugeot 205 with broken shocks.Feels the same.Only was not tilting.how much would it be for shock and springs.
Blue MK2
« Reply #7 on: 14 December 2004, 00:39 »
hi nel,
standard shocks and springs.....
http://www.vwspares.co.uk/g2suspension.html
Offline tinman
« Reply #8 on: 14 December 2004, 00:50 »
yeah, exactly.
if the car has had the engine out for any period of time the front springs can also stay a bit high, or sink when the engine is put back in. they have a mind of their own.
Offline Gambit
« Reply #9 on: 14 December 2004, 09:13 »
inspection time methinks
sounds like the top mounts (or a top mount!) to be honest
