Author Topic: Suspension trouble  (Read 2661 times)
Veedubgt18v
Re: Suspension trouble
« Reply #10 on: 14 December 2004, 09:16 »
shocks dont keep the car up tho. if you took the springs out it would be on the deck! i reckon springs.
yeah, exactly.
if the car has had the engine out for any period of time the front springs can also stay a bit high, or sink when the engine is put back in. they have a mind of their own.
we agreeing on something tin?  :wink:
Veedubgt18v
« Reply #11 on: 14 December 2004, 09:17 »
inspection time methinks
sounds like the top mounts (or a top mount!) to be honest
but 3 cm's is like over an inch, if its a top mount that is absolutely f**ked! mine were shagged totally and only gave half that play!
Offline Neel
« Reply #12 on: 14 December 2004, 23:38 »
Thanks for all the help from everyone.Im going to check out the shocks.Think it would be the top mounts aswell.
How hard is it to change the shocks and everything on a vw?
How many hours to do all four?
Veedubgt18v
« Reply #13 on: 15 December 2004, 08:07 »
if you know what your doing then about 45 mins a side for the front and about 45 total for the back i would say. when you come to do it let us know and i will post up here how you do it. it is in the haynes manual tho. one tip remove both rear shocks at the same time but support the swing arm
