Hi guys, I have a couple of minor problems with my 2001 20v Turbo Gti.
Firstly, my engine light came on, Rhyso cleared the code and the code which came back was 'Boost Pressure Control Valve Malfunction'
(The light has not come back on though)
So I went hunting for loose pipes, and the only one I can spot is the one circled in red in the attached photo, the inside of the elbow has totally perished, letting in un-metered air.
Uploaded with
ImageShack.usSecondly, under acceleration i can feel the car judder ever so slightly, or more accurately i would say a slight hesitation due to a small loss of power for a split second.
Lastly, when accelerating, if I change up a gear, I can hear a few small chirpping noises like 'pip pip pip' coming from the engine bay when im between gears. - not sure if this would be the re-circ valve not doing its job?
So, Im just wondering what course of action to take? Obviously change the breather pipe for starters, but what then - should I change the BPCV as a precaution and are they expensive.
Also as for the pip pip pip noise, im open to suggestions there?!
Thanks for reading!
Ger
