Author Topic: GTI Turbo stuttering and chirping noises..... (Rhyso has done me a fault read)  (Read 6673 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
causing the "sneezing pigeon" noise on gear changes.
that has made my day  :grin: :grin:
Offline gerlewis
Well, the recirc valve just arrived in the post, and the dog has beaten me to it and chewed it in half (well annoyed).
Anyone know the part number so I can order one from dealer?
Thanks
Ger
Offline Rhyso
Thanks
Ger
If you're on about the DV then get a Forge 007p - you'll never have to replace it (hopefully) unlike the standard one which you'll be replacing in a couple of years
Offline gerlewis
im not sure budget permits. do you have the dealer part number and price? or a 007p price?
Offline gerlewis
Ive just fitted a new Blow-off Valve from the main stealers, and I 'think' the problem might be fixed!
I need to take it on a longer trip to be sure, but initially it seems to have stopped making the noise. Fingers crossed!
Now I can get back to saving for them keskins!
Thanks for all your help so far guys!
Offline gerlewis
Quick update: No more chirping noises, I think that problem is fixed.
One problem though, the cheap plastic pipe which goes into the bottom of the silicone T shaped pipe I replaced has split where it goes into my new silicone pipe!
Is there an aftermarket pipe I should look into getting to replace it? or does anyone else have experience with this pipe breaking?
Also, I still have a slight wooshing air sound as if there might be another air leak somewhere else? Is the pancake pipe a suspect? (Ive checked all the pipes on the top of the bay and they are fine). whats the best way to get a peak at the pancake?
Ger
