Author Topic: GTI Turbo stuttering and chirping noises..... (Rhyso has done me a fault read)  (Read 6673 times)
Offline Stronz
  • Sold!
Lol, I didn't even remember to request a colour, but got sent a blue one. Considering replacing a few other pipes now to match in and tidy the bay up a bit..
Offline Big Tone
I have a black y shaped breather and a blue lower breather, because I made the same mistake of not requesting a colour.
Fancy swapping? only three months on the car
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline Rhyso
I'd start by replacing bits you know are faulty / have splits in
Worry about the N75 AFTER you've replace the breather hose.  That way you'll hopefully end up sending less on parts :afro:
You need to eliminate the known problems first  :wink:
Offline gerlewis
good point, fancy doing me a code read once I have replaced the pipe? (i can come to you)
The only other thing is the chirping noise... which is why i was looking into n279 n75.
One step at a time though eh!
Offline Rhyso
No probs - drop me a text when you've replace the hose  :smiley:  Perhaps try and do some proper data logging too  :smiley:
Offline gerlewis
ok, Ive replaced the hose - cheers all for the heads up regarding the ebay silicone one!
(Ive also replaced the fuel filter due to a random leak!)
I still have the chirping noise (more of a fplfplfpflll - according to my wife) on gear change (and a slight whistle when accelerating), I am waiting on some second hand bits to arrive (n75 and recirc valve) - see if they make any difference.
Ger
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
recirc valve could well be dead, or a leak in another hose somewhere...
Offline gerlewis
hopefully the bits will arrive tomorrow. I will keep you posted.
Offline topher
  • Administrator
  • fully functioning
what was the exact fault code?
a faulty dv can throw throw false positives, particularly n249 related fault codes. I wouldn't even touch the N75 until the dv is checked/replaced as that is what will be causing the "sneezing pigeon" noise on gear changes.
