Author Topic: 17705..............  (Read 4122 times)
Offline northeast_gti-t
  • "1.8T AGU"
17705..............
« on: 13 May 2010, 17:08 »
Well after fitting my replacement lower chargepipe/pancakepipe boost hose the car seems really strong now and boosting as it should had a nice run both to and from work so about an hour ago i hooked it up to vag com to see if i had the code i cleared it the other weekend so was expecting it to be there and it was  :sad:
so cleared and been out for abit of a run got it back on vag com for a re-check and.................................
No 17705.......... :smiley:
2000 Mkiv GTi 1.8T AGU
Offline Mr_Orange
Re: 17705..............
« Reply #1 on: 13 May 2010, 17:17 »
Hope its gone for good!
Same thing here, I couldn't prevent it coming back.  I flung numerous bits and pieces at it, but I think the final solution for me was a new 90° boost elbow at top of turbo (previously had oil vapour on top of turbo silencer).
Build thread clicky
Offline RTechUK
  • R-TECH OFFICE 01455 617233
« Reply #2 on: 13 May 2010, 17:36 »
17705 = driver error you not using all the power and boost is going to waste  lol :grin:
Nick
 01455 617233
Offline T_J_G
« Reply #3 on: 13 May 2010, 17:41 »
Still need to fit my Forge one of those :lipsrsealed:
Offline Mr_Orange
« Reply #4 on: 13 May 2010, 17:48 »
Fitting a new standard one was a pig, so I guess a super solid aftermarket one will be a right pain!
Build thread clicky
Offline Big Tone
« Reply #5 on: 13 May 2010, 18:03 »
I had same problem. pressure test confirmed that the new pipe also leaked! so what I did was trim the stainless pipe's lugs back so that the o ring seats further back into the pipe. then gently bend the lower lugs to clamp the pipe ho place and prevent it from moving out. be careful though, only trim a bit off at a time because you can't stu material back on the pipe. problem solved, providing there's no leaks anywhere else ho the pipework. plus it still looks standard
****FOR SALE**** 11 Months MOT, 5 Months Tax - 1.8T AUM, Stage 1 map, Lowered 35mm on Jamex Springs, Smoothed Airbox, Pipercross Panel, Forge 007P, N249 Bypass, Silicon Breather Hoses,Silicon Vac Hoses, Top Mounts & Bushes All Round, Catch Can Install,  New Discs and Pads All Round, A Big Sub, A SH*TLOAD of Polishing and A Thirst For V-POWER! Profile/msg for info!
Offline richw911
« Reply #6 on: 13 May 2010, 19:33 »
Nick
lol  :grin: :grin:
Offline Rhyso
« Reply #7 on: 13 May 2010, 20:55 »
What's 17705?  :huh:  :tongue: :smug: :grin: :grin: :grin:
  • "1.8T AGU"
« Reply #8 on: 13 May 2010, 22:06 »
:tongue: Ah the man himself  :grin: your links responsible good read tho all the same :afro:
  • "1.8T AGU"
« Reply #9 on: 13 May 2010, 22:08 »
Hope so too :lipsrsealed:
i did think about replacing that hose also but it seems ok although the jubilee was not that tight well it is now  :grin:
