Author Topic: 17705..............  (Read 4089 times)
Offline Rhyso
Re: 17705..............
« Reply #10 on: 13 May 2010, 22:09 »
What's 17705?  :huh:  :tongue: :smug: :grin: :grin: :grin:
:tongue: Ah the man himself  :grin: your links responsible good read tho all the same :afro:
I think the problem you get with this sort of code is you possibly force the leak around the system so the only way to cure it in one go is to replace EVERYTHING  :sad:
And learn to multi-quote  :tongue: its not difficult!
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #11 on: 13 May 2010, 22:10 »
17705 = driver error you not using all the power and boost is going to waste  lol :grin:
Nick
Cheeky git  :grin: :tongue: i'm using it now as my mpg can confirm  :lipsrsealed: :evil: need me a fmic nick and then you to put a stage 2 map on  :wink: :evil:
2000 Mkiv GTi 1.8T AGU
  • "1.8T AGU"
« Reply #12 on: 13 May 2010, 22:13 »
Reckon your right rhys theres not much else to go at all the crap pcv systems gone vac stuff altered or replaced and now the hose seems to have cured it  :lipsrsealed: time will tell i think
 :grin: Matt and multi quote = Fail
Offline paulturbo
« Reply #13 on: 20 June 2010, 21:34 »
anyone got a pic or description of where this offending pipe is?
  • "1.8T AGU"
« Reply #14 on: 20 June 2010, 21:48 »
here you go  :wink:
hope that helps you out
Offline paulturbo
« Reply #15 on: 20 June 2010, 22:04 »
ta very much, i will look at mine now tomorrow now i know what i am looking for.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #16 on: 20 June 2010, 22:19 »
yours is a gay clip, mine has a proper jubilee clip holding it together  :smug:
  • "1.8T AGU"
« Reply #17 on: 20 June 2010, 22:32 »
ah but its doing its job now  :smug: no leaks anywhere and i think since fitting my new map sensor boosts back as it should be  :wink:
Offline Pat
« Reply #18 on: 21 June 2010, 17:02 »
I guess it's only a matter of time before that new pipe & seal fails though :angry:
I bought a brand new one a few years back, it's still sat at home as I never fitted it
Did an AGU pipe instead with a Mikalor holding it tight, it's never coming off again *fingers crossed*
  • "1.8T AGU"
« Reply #19 on: 21 June 2010, 21:42 »
fingers crossed  :grin: :lipsrsealed:
thats right i remember reading up on that topic what you posted to on ukmkivs quite a lenghty topic that was
