Author Topic: Pioneer AVic F910BT>>>>>>all in 1 DVD SAT NAV BLUETOOTH  (Read 6511 times)
Offline nadlad
  • Building Surveyor MRICS
now then,
thinkign of getting a all in one system for my car, such as this one
http://www.dynamicsounds.co.uk/pioneer-avicf910bt-navigation-system-bluetooth-ipodiphone-card-p-9797.html
ideally i need a usb input a decent hands free such as built in parrot  and a sat nav syatem built in... at the moment am still fully reasearchiing into this as i also want to be able to get longwave radio so i can listen to cricket test match special.... sad i know but u know.
i was just wonderign what your opinions on this system are and if theres any pics of it installed in a mk4 cheers.
nad
<<<Big Build Thread>>>
Offline troublestarter
they are very good units but the start up time is very slow and sometimes it can take a while to read a memory stick
from a personal experience i find customers would rather have an equivelant kenwood like the current DNX-5260BT
www.awesomeautomotive.co.uk<br />mobile vehicle security & audio fitting service<br />insurance accredited
Offline nadlad
yeah that looks good u know, good alternative its got the LONGWAVE radio which i need, i wonder what the handsfree is liek , if it spowered by parrot liek the pioneers it shud be good, coz the one in the 90bt pioneer is crap.
Offline nadlad
how many outputs does the kenwood have, am runnign a sub and amp
the bluetooth is a parrot kit built in and works brilliantly and it has 2 pre outs one for front and the rear is switchable to sub out aswell
the h/u has built in high and low pass filters aswell
Offline nadlad
whats a high and low pass filters?
at the mo i have the pioneer 80bt headunit, i think it has 3 outputs... ave got a sub runnign and the front speakers are runnign on sep channels
Kenwood DNX-5260BT Audio features:
    * Max. Output Power (MOSFET Power IC) 4 x 50W
    * Pre-out 3RCA: Front/Rear/Subwoofer
    * Pre-out Output Level 2V
    * Auxiliary Input AV Front Input with optional CA-C3AV
    * Rear / Subwoofer Switchable
    * Subwoofer Reference Level Adj.
    * Dual Zone Source & Volume Control
    * Dual Zone (FRONT / REAR Switchable)
    * Source Tone Control & Memory Bass / Mid / Treble
    * Balance/Fader Control
    * Loudness Control
    * Att.(-20dB) with smooth Volume Return
    * System QEX (Preset & Manual Sound Control)
    * System E's+ (Built-in HPF & LPF)
    * Beep On/Off
the pioneer 80bt the one i cuurently use has this
Connectivity
    * Aux-in (Rear)
    * iPod Direct Control
    * USB Input
    * IP Bus
    * 3 RCA Preout (F+R+S/W or NON-FAD)
    * Sub-display Output
    * Hard-wired Remote Input
    * Direct Sub Drive
    * 4V High Voltage Output
    * Full Control Expansion Units - Multi-CD, TV, Multi-DVD, iPod
    * Partial Control Expansion Units - DAB
what is the difference between the 4v high voltage output (pioneer 80bt) and the 2v output that the kenwood has?
high and low pass filters means crossovers
just remembered the 5260bt had three i was thinking of the older model
the only difference between having 4v pre outs rather than 2v means when running off amps the 4v signal from the h/u just means the gain on the amp would not need to be set as high as a 2 volt preout
so in essence if you got the kenwood you may need to turn your gains up slightly on the amps to match the output of the previous pioneer unit
Offline nadlad
oh right so barely noticeable then...
now i need to find one for around 300 lol
GOOD LUCK its a new model
Offline nadlad
whats the model before that one, as in they must fo doen an end of line equivalent model before bringing this one out of similar spec?
