Author Topic: Wazzzer's 1.8T... Lots of updates  (Read 403264 times)
Offline Dave_IOW
Re: Re: Wazzzer's 1.8T... ECU etc fitted
« Reply #450 on: 01 February 2013, 19:26 »
Your MAF reading G/S is basically how much air is travelling through the MAF which in turn, you can roughly work out your HP, there's a calculation somewhere for a standard housing, obviously this being wider, would need a different multiplier.
Your specified load and actual load is to do with what the ECU is being shown what's going on, and what is actually going on I think, how to check for boost leaks etc..
Good luck tomorrow Wes, let's hope for good figures :)
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline Chris.
« Reply #451 on: 02 February 2013, 00:47 »
Tells you quite a lot really.
Airflow readings from the MAF can give indication of a failing MAF, work out bhp roughly (altho its never precise in wazzers case due to setup), how hard the N75 valve is working to meet the boost (load in ME3.8), also can give signs of a weak actuator/limp mode.
Knock is a pretty handy one too....in this case wazzers are all 0* correction factor...this means ECU is not detecting any knock in the cylinders and not pulling the timing back.  probably due to the meth running which helps a lot....a fair amount of timing can be added there.  Probably on ball for quickest (highest BHP) AGU k03s if he took it back to nick and got my map altered.
If he went and logged the lambda voltage one (whichever block it is...9?) can work out a basic AFR map and plot it see whats happening fuelling related.
Click For Build Thread
Offline stow1985
  • 'when im cleaning winders'
« Reply #452 on: 02 February 2013, 16:34 »
interesting to know :smiley:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #453 on: 02 February 2013, 18:06 »
lots of fuel where it shouldn't be but at least it's safe...
Offline Rhyso
« Reply #454 on: 02 February 2013, 18:08 »
So what did it make??
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #455 on: 02 February 2013, 18:12 »
Same as my sig pretty much
Offline Rhyso
« Reply #456 on: 02 February 2013, 18:12 »
No missing horses today then   :laugh:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #457 on: 02 February 2013, 18:16 »
Yes as I have bigger MAF and and injectors in there. Running rich (10.5) but It's safe and still a nice curve. Pics to follow
Offline Rhyso
« Reply #458 on: 02 February 2013, 18:18 »
Take it you haven't had it mapped to take them into account though?
Offline Chris.
« Reply #459 on: 02 February 2013, 18:23 »
Its mapped for yellows and VR6 MAF....JKM dyno underreads a bit, Prawn saying its a heartbreaker dyno.
