Author Topic: Wazzzer's 1.8T... Lots of updates  (Read 403268 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Re: Wazzzer's 1.8T... ECU etc fitted
« Reply #430 on: 26 January 2013, 09:11 »
Shaun - cheers mate, been putting this off for ages but it wasn't too bad. I was originally going to be doing it on the road but managed to squeeze the Golf in my parents garage with both wing mirrors tucked in lol
Chris - only thing I can think of is that I've got immo3 clocks in there so that might have been the reason. All solved once I remembered how to code the keys again.
I'll get some logs later if the rain dries up and send them through to you mate, cheers. What blocks do you think I'll need to log?
Offline Dave_IOW
« Reply #431 on: 26 January 2013, 13:46 »
Looks good mate, is it mapped for meth?
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
Offline dom
  • Back in a Mk4
« Reply #432 on: 26 January 2013, 14:26 »
Silencer fitted ok then? Got a link to the eBay listing?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #433 on: 26 January 2013, 14:44 »
I got a pic while the car was up on the ramps especially for you Dom, just uploading it
Offline dom
  • Back in a Mk4
« Reply #434 on: 26 January 2013, 15:03 »
:afro:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #435 on: 26 January 2013, 15:08 »
Spent the morning after work sorting the exhaust and I think we've got it pretty much bang on (by that I mean there is about 1mm between the beam and the U clamp when it's on its wheels)
It was decided to do it properly so the rear box had to come off and be cleaned up
All fixed in position now and it's not moving at all :afro:
Just need some logs now and a good wash then I'm ready for Sat
Dave - no not mapped for meth so I'll do some logs with and without and see what difference it makes. I'll be getting the map tweaked at some point anyway
Some of the heat shielding needed "adjusting" though lol
And a pic of the silencer fitted, fits perfectly in the gap
Offline Chris.
« Reply #436 on: 26 January 2013, 15:46 »
002, 013 , 025 should do it mate.
Click For Build Thread
Offline stow1985
  • 'when im cleaning winders'
« Reply #437 on: 26 January 2013, 16:16 »
Nice...whats the advantage of VR6 MAF?
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #438 on: 26 January 2013, 16:24 »
Cheers mate. VR6 MAF has a bigger diameter which is needed for bigger injectors. It's not something you can just fit in and run, you need your map adjusted to suit
Offline stow1985
« Reply #439 on: 26 January 2013, 20:01 »
Interesting...where do you get all you technical info from??  :grin:
