Author Topic: Wazzzer's 1.8T... Lots of updates  (Read 403276 times)
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wazzzer's 1.8T... custom Bora Sport clocks assembled
« Reply #350 on: 21 July 2012, 16:02 »
Had a bit of time to play about today so I decided to sort my pipe route at the back end for the WMI as I wasn't 100% happy with it
Result is I managed to lose about a foot of pipe and it's a bit more direct now
Underneath
Inside the boot
I also added my tap in case I ever need to shut off the system and remove the tank (like when I fit my float switch)
Then I moved to my throttle housing to see if I could get any more angle on the butterfly. The missus wouldn't come out to keep the throttle pedal pressed so I replaced her with a piece of wood  :grin:
Luckily my VAG COM cable is log enough to get the laptop in the engine bay with me  :smiley:
VAG COM reading as standard
and a screwdriver to open it a bit more...
Then the reading fully open
so I've now got to dremel a bit of the stop away on the throttle housing to get it to open up fully, I'll do this once I can get the car outside my house to run some power out there  :wink:
Offline andynorfolk
  • if at first you don't succeed, get a bigger hammer
Re: Wazzzer's 1.8T...WMI tinkering again
« Reply #351 on: 21 July 2012, 17:36 »
properly admire your commitment and knowledge with this, one of the best threads i think i've seen for attention to detail :D
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #352 on: 27 July 2012, 17:49 »
thanks mate
Sorted out the throttle stop with my dremel
The wife's replacement holding WOT  :grin:
The stop ground back, not pretty but you can't see it unless you look for it
and the result..
:afro:
The comfort indicator parts are here and waiting to be fitted
and I've soldered the wires ready for the clocks changeover, nicely numbered both ends with some labels from work  :wink:
I'll try to get started on it over the weekend but I'm lacking an outside temp sensor. I have one from a Passat but not sure it will work, only one way to find out  :wink:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
Re: Wazzzer's 1.8T... throttle stop adjusted
« Reply #353 on: 27 July 2012, 18:14 »
Just means the throttle butterfly is a little bit less restrictive as it's near enough at 90° so will be flat.
The comfort indicators blink 3 times when you flick the stalk, good for quick signals on the motorway etc
Re: Re: Wazzzer's 1.8T... throttle stop adjusted
« Reply #354 on: 27 July 2012, 22:23 »
How much was the comfort indicator set up.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #355 on: 27 July 2012, 23:47 »
£32 mate  :smiley:
« Reply #356 on: 28 July 2012, 09:11 »
£32 mate  :smiley:
Cheers :cool: does it look easy to fit.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #357 on: 28 July 2012, 09:17 »
Yeah it's just a case of popping about 4 wires out of the original multi plug then just following the diagram.
« Reply #358 on: 28 July 2012, 09:28 »
Thank you :smiley:
I shall have a think about getting a kit.
Offline Dave_IOW
« Reply #359 on: 28 July 2012, 14:59 »
Necessity for the Isle of Wight   :grin:  :kiss:  :laugh:
Project: Mk2 20vT trackslag
Daily: Mk2 GTI typ19
