Author Topic: any extra oomppff??  (Read 5453 times)
Offline player.777
any extra oomppff??
« on: 26 April 2010, 19:13 »
Guys, my old man is coming over from Oz in three weeks and he hasn't been in the car since the re-map. I have dropped a bottle of Forte treatment in, but what else can I do, or book in for, to give it any extra BHP it may be losing??  To give it a little tweak before he has a go?
Offline Rhyso
Re: any extra oomppff??
« Reply #1 on: 26 April 2010, 19:24 »
Innotec Turbo Cleaner :afro:
Replace all o-rings and clip fittings
Turbo back exhaust
How deep is your wallet?  :grin: :grin:
Offline player.777
« Reply #2 on: 26 April 2010, 19:35 »
thanks mate- i take it the turbo cleaner in question is this one? http://www.innotecworld.com/c-1064-turbo-clean-set.aspx  Did it make any difference you reckon?   I have checked and replaced a few clips a while ago, will have another look and see. can't afford a new exhaust now- am moving house this friday (aagghh!!) so all money (and a lot more) tied up in that.
Offline Rhyso
« Reply #3 on: 26 April 2010, 19:39 »
That's the stuff :afro:
I find my car smokes a lot less since having done it - got another issue so can't really comment on its full benefit but others have had it done and comment that the engine is far more responsive  :smiley:
I know Steve did it on his and he hasn't (not to my knowledge) hit limp mode since.  Having been out in his car last week I can confirm its proper quick :afro:
Not much more you can do then apart from check fluid levels and tyre pressures etc
Also make sure your wheel alignment is spot on to aid cornering and sure-footedness
NOt much more you can do then
Offline player.777
« Reply #4 on: 26 April 2010, 19:43 »
ok great, i'll call up and get that ordered tomorrow. cheers bud
Offline Rhyso
« Reply #5 on: 26 April 2010, 19:47 »
you got a garage who can do it?? Otherwise it will mean lying flat on your back wiggling your actuator  :laugh: :laugh:
Offline player.777
« Reply #6 on: 26 April 2010, 19:48 »
ahhh bugger- is it not a DIY job then??
Offline Rhyso
« Reply #7 on: 26 April 2010, 19:55 »
not really know unless you get a decent jack and axle stands
you need to remove the downpipe off the turbo as you inject the cleaner directly into it
Its an hour's labour
Offline player.777
« Reply #8 on: 26 April 2010, 20:00 »
ok.... decent jack- uncheck, axle stands- uncheck, fine I'll get someone else to do it!!!!!
Offline Rhyso
« Reply #9 on: 26 April 2010, 20:01 »
wise move  :smiley:  Make sure they replace the gasket between the turbo and downpipe - about £3 from the dealers  :wink:
