Author Topic: GAMMA HEAD UNIT & CD PLAYER - FITTING ADVICE PLEASE......  (Read 4271 times)
Offline green_rizla
Hi All,
I've bought a Gamma Radio and a VW CD player to go in the dash ..................... I know, I know, I know ........
I'm taking out the Sony unit that is in there..............
So, I'll end up with a hole for the Gamma radion which seems straight forward enough. I have the code and a user manual.
At the moment there is a storage pocket where the cd will go............. ?????
1. How do I get the storage pocket out ??????
2. will the cd player just sort of slide in ????? ............. or is there other stuff I need ????
Any advice here would be greatly appreciated.
Peter
If everything seems under control, then you aren\\\'t going fast enough.<br />(Mario Andretti)<br /><br />MK4 GTI 1.8 Turbo - Jazz Blue <br />Recaro Interior and all the electric stufff !!!!
Offline Rhyso
Re: GAMMA HEAD UNIT & CD PLAYER - FITTING ADVICE PLEASE......
« Reply #1 on: 26 April 2010, 11:37 »
storage pocket will slide out - you might have to get a flathead screwdriver in at the edges to release some locking tabs
CD player will then slide in  :smiley:
There should be a triangle divider between the two - not sure if you got that already  :undecided:
Offline green_rizla
« Reply #2 on: 26 April 2010, 11:46 »
Thanks................ THis triangle divider ???? .................... If there isn't one. is it essential or can I just use some kind of shim / spacer ????? ................ If not where can I get one ???? ............. VAG dealer ????
Peter
Offline Rhyso
« Reply #3 on: 26 April 2010, 11:52 »
Peter
Kind of as it will stop the two units resting against each other
Ebay, scrapyard, classifieds or the dealer  :smiley:
Part number 1J0 857  725 C - no more than £10 from the dealer :afro:
Offline green_rizla
« Reply #4 on: 26 April 2010, 12:11 »
Peter
Much appreciated
Thanks
Offline green_rizla
Re: GAMMA HEAD UNIT & CD PLAYER - FITTED
« Reply #5 on: 27 April 2010, 13:57 »
 :smiley:
I've fitted the Gamma Radio and the CD player .................... Made up my own spacer.
Couldn't get the radio to work at first then found this plugged into the cars power thingy that plugs into the radio.......... Apparently it's some thing you need when you fit an aftermarket radio. Tells the radio the aerial is 1.5mtrs long or somesuch thing.............
All I need now is some king of lead that I plug in the back of the cd player so it lights up when I swith the lights on ????? I think ????? .............. Haven't got a clue what this is about .................. Phoned a VW delear and that was trying to talk to the "perplexed" ................. Anyone know what this is, where I get one or what the part number might be ????
Cheers to All
Peter
Offline green_rizla
Hi All,
Still after lead that I plug in the back of the cd player so it lights up when I switch the lights on ?? I think ?? .............. I called into a VW dealer today and they had no idea what I was talking about.............
Does anyone know anything about these ????? .............. Have one kicking around they don't need or can give me a part number ????
Cheers to All
Peter
