Author Topic: what would YOU do to a 16v engine whilst it's out  (Read 9064 times)
Offline Khare
  • The bear that khares
Re: what would YOU do to a 16v engine whilst it's out
« Reply #50 on: 12 April 2010, 00:03 »
and from that £60 I have to buy oil, PAS fluid, Brake fluid, oil filter + flush and the rear beam bushes.
Offline Ben Lessani
« Reply #51 on: 12 April 2010, 00:05 »
£60 will barely cover the swear word jar during the swap, give up now :laugh:
Offline Matty-MK3
  • Automatic boats FTW.
« Reply #52 on: 12 April 2010, 00:07 »
Service, rob DH for other parts. PAS fluid is auto box fluid. ;) Cheap engine flush.
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
Offline Khare
« Reply #53 on: 12 April 2010, 00:13 »
Dizzie cap, rotor and leads are 2 months old, and spark plugs I've not yet checked (don't have a spark plug tool thin enough to get though the holes).
PAS fluid I'll try and save as much as I can from draining it, hopefully from both cars I'll be able to get enough for 1 system.
Offline danny_p
« Reply #54 on: 12 April 2010, 00:27 »
cranck position sensor ( unless  it looks optimal )
cam belt
rocker gasket
plugs
oil
filters.
check
rear cranck oil seal
frount cranck oil seal
cam oil seal
dizzy oil seal
clutch
all the VW's have gone bar 1.
Offline Khare
« Reply #55 on: 12 April 2010, 00:32 »
cam belt
rocker gasket
plugs
oil
filters.
check
cam oil seal
dizzy oil seal
clutch
Where is the CPS on the 16v's? I'll check it out.
Offline monzablue16v
« Reply #56 on: 12 April 2010, 02:19 »
After reading the thread I would do sh!t loads more than you are going to, HTH :P
Offline Khare
« Reply #57 on: 12 April 2010, 02:23 »
I wish I could rebuild it! But As I said, I've got about £60 to spend on the essential stuff, so I can't go around blowing money on other stuff.
« Reply #58 on: 12 April 2010, 09:40 »
With respect trying to a job of this scale on a budget of peanuts could / may end in tears.
I would not be keen on reusing pas fluid etc.
kells
« Reply #59 on: 12 April 2010, 10:07 »
i would wait till you can afford to do things properly, dont see the point in rushing things, do it once do it right...
collect all the parts you need then bob is your auntys unkle
guessing this will fall on deaf ground tho
