Author Topic: what would YOU do to a 16v engine whilst it's out  (Read 9102 times)
Offline Matty-MK3
  • Automatic boats FTW.
Re: what would YOU do to a 16v engine whilst it's out
« Reply #30 on: 11 April 2010, 23:14 »
Sorry I was taling about water pumps etc. :grin:
Golf MK3 1.8 auto and I didn't pay a grand for the "priveledge" :grin:, auto windows all round and a AC. Oh and I've got a luggage net you pricks!
Does that make my willy look bigger?
Oh yeah it's called Helda or something....
Offline Ben Lessani
« Reply #31 on: 11 April 2010, 23:16 »
Try Superflex or Bugpack - they're usually a spot cheaper.
Offline Khare
  • The bear that khares
« Reply #32 on: 11 April 2010, 23:21 »
nothing, if anything superflex is a tad more expensive than powerflex.
I'll settle for standard rubber bushes by the looks of it.
Offline tg1
« Reply #33 on: 11 April 2010, 23:22 »
you could always fill the bushes with windscreen sealant, depends on how pikey you are.  :lipsrsealed:
you thought about rocker cover, inlet to block gaskets?
new sump gasket, plug?
t/b gasket
Engine flush
check the bearings on the car
Offline Ben Lessani
« Reply #34 on: 11 April 2010, 23:32 »
How about Prothane?
Offline Paul86S2
« Reply #35 on: 11 April 2010, 23:36 »
Do the cambelt whilst the engine is out its a lot easier and well worth the insurance.
Cam cover gasket is just as easy to do with the engine in the car.
The plastic water flanges on the front and side of the head are prone to failure but again are easy enough to change with the engine in.
Paul
Offline Ben Lessani
« Reply #36 on: 11 April 2010, 23:40 »
If you change these - USE GENUINE, Gsf/ECP are sh!tters and tend to warp within 12 months.
Offline Khare
« Reply #37 on: 11 April 2010, 23:43 »
I WILL use genuine if I change them. From previous experience they tend to warp after a month or two. I've changed about 3 or 4 now.
I'll try prothane  :smiley:
Cam cover gasket and other superficial gaskets are pretty easy with engine in the car, so they ain't too important.
Offline Ben Lessani
« Reply #38 on: 11 April 2010, 23:45 »
Rear engine mount might be worth a quick inspection too - much easier with the engine out of the car.
What is the situation exactly - you're putting an ABF into your shell - or just rebuilding an ABF and putting it back into its original shell?
Offline Matty-MK3
« Reply #39 on: 11 April 2010, 23:47 »
Let's all not start a debate on whether it's worth it or not AGAIN but he's taking a 16V ABF from one car and putting it in place of his 8V.
