Author Topic: Catch can problem!  (Read 1657 times)
Offline DarkGti
Catch can problem!
« on: 01 April 2010, 17:49 »
Right! After installing my Saikou Michi catch can and removing all the pcv system i have a problem, when my car comes to idle after revving the rev's drop like its going to stall but dosent and the revs rise again and its fine has anyone got any ideas what this could be?
p.s all the hoses are tight and jubilee clipped!
Offline Purely VAG
Re: Catch can problem!
« Reply #1 on: 01 April 2010, 20:11 »
Is the crankcase ventilation pipe sealed in properly, has a u-clip over it, that can be quite a little sh!t to get back in properly
✉ Jrd@PurelyVAG.co.uk // www.PurelyVAG.co.uk
Offline DarkGti
« Reply #2 on: 01 April 2010, 20:33 »
yea that pipe fitted and U clip fitted properly
Offline james2
  • No scammers please.
« Reply #3 on: 01 April 2010, 22:47 »
i would double check everything and anything you moved to get it to fit in  :huh:
AGU 1.8T. Mods done: R32 front bumper, turborev smic, ngk platinum spark plugs, uprated pancake pipe, demon motorsport boost hoses, forge 007 dv, forge engine cover, r-tec stage 1 map ,home made cold airfilter ,run on 98 ron fuel and castrol edge 0w 40 oil. Advanti racing alloys.
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #4 on: 01 April 2010, 22:53 »
Have you reset the throttle body? Mine took a while to get used to not having the PCV system, just give it some time. Oh and I know this sounds patronising but is the tap on the bottom shut? I needs to be wound out as far as it will go to be shut
Offline DarkGti
« Reply #5 on: 02 April 2010, 10:32 »
Sorted know i forgot to tighten the jubilee clip on the hockey puck thing and it came out! derrrrrr :embarassed:
Offline Wazzzer
  • Moderator
  • Golf GTI 1.8T AGU
« Reply #6 on: 02 April 2010, 11:45 »
you fool lol
I've ditched my hockey puck  :wink:
Offline northeast_gti-t
  • "1.8T AGU"
« Reply #7 on: 02 April 2010, 13:30 »
ooops  :grin: ah well at least you found the problem out easy enough tho  :wink: i did the same as wes and removed my hockey puck just a 90 degree elbow in mine  :wink:
2000 Mkiv GTi 1.8T AGU
Offline DarkGti
« Reply #8 on: 02 April 2010, 13:53 »
yea going get a 90 degree elbow today and get rid of it as well!
Offline DarkGti
« Reply #9 on: 02 April 2010, 14:00 »
